Results 1 to 14 of 14
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Details Request: Intake mod
    Ok, so far Ive got a Greddy FMIC and a Heat shield from 00black1.8t that I am preparing to install next week. I was looking for anyone with a similar setup to see what size cone I should be running, the inlet size of the intake, and any other general suggestions that anyone may have so that I am not running to get parts without a bumper in the middle of the install(done it before). Pics are always welcomed!
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    Established Member Two Rings lak2881's Avatar
    Mar 12 2007
    A4 B7 Sline Ti pkg.
    Re: Details Request: Intake mod
    I am also intested in doing this. I have seen it done on a couple cars but i dont have any other useful info on how to do it.
    2010 A4, 6sp quattro, Sport package, Bluetooth, Homelink.
    2007 A4 S-Line Ti Pkg 2.0t 6sp fronttrack, H&R Sport Springs, H&R rear sway bar, Front filler plate, debadged, 35% window tint, REVO, 10mm front 12mm rear H&R spacers.
    2004 A4 1.8t 5sp fronttrack, H&R sport springs. Forge diverter valve.
    Registered Member Two Rings hypnoticboi19's Avatar
    Aug 05 2007
    2008 Audi A4 2.0T S-line
    San Francisco
    i just took off my factory airbox and slapt on a filter. sounds hella mean. nice blowoff sounds without the valve. and i used my factory heatshield. custom lol
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Quote Originally Posted by hypnoticboi19 View Post
    Just started puling it apart, will post pics when done..im not sure how you used the factory heatshield but good job!!
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    SWEET!! Its installed, with no problems.. Took about an hr max, the heat shield K&N filter combo is defn worth it. Faster turbo spool, virtually no lag what so ever and the DV and Turbo are loud as $**$. Spent 90 on the heatshield, and then another 65 on a K&N cone filter. Looking to replace the stock rubber hose going to the turbo with aluminum tubing to reduce air resistance even more, this should be done next week. As far as pics, I will get them up as soon as i find my camera which might take a while (just moved). This project was a great deal, and at 1/2 the price of the other options, next on the list is the FMIC in a couple of days.
    Jun 08 2007
    Quote Originally Posted by B7 Projectile View Post
    where did u get the K&N intake and heat shield.
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Quote Originally Posted by A-List View Post
    K&N-Auto zone
    Heat shield-00black1.8t
    Registered Member Three Rings era's Avatar
    Feb 01 2008
    2008 A4 2.0T Quattro TIP
    Brooklyn NYC
    What size cone did you use?
    Also do a DIY !!
    - Debadged - Blacked-out RS4 Grille - Prolumen 6000k HID - Llumar 35%/15% - Höen Fogs - CC Mod - VAG'd - Gun Smoked Tails -
    - Blacked-out Housing - VAG'd - CF DTM Style Spoiler - Painted Red Calipers - Red Interior LEDs - Stasis SS CO - Angel eyes -
    About to install:
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Quote Originally Posted by era View Post
    Also do a DIY !!
    Planning on it, but my front end is torn apart while I put on this Greddy FMIC and HID fogs, planning on doing a DIY on the fogs if this all works out correct.
    Established Member Two Rings GEkido's Avatar
    Apr 25 2008
    Miami, FL
    Thumbs up Re: Details Request: Intake mod
    Subscribed! Take lotsa pics too!
    2021 S5 Sportback | Glacier White | Sport Package | Black Optic | APR 93 Tune | APR FMIC | AWE CF Intake | 034 F.S.B. | 10/12.5mm Spacers
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    for just the fogs, you don't have to take the bumper off. it's just a few screws, a few tugs on the housings, and a couple twists to get the bulbs out and back in.
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Quote Originally Posted by AAAA View Post
    So true for the regular bulbs, but you must also find room for the HID ballast and mount them. I have already found my mounting location on the inside of the bumper so that when I take the bumper off in the future its just an unclick of the one OEM plug and its ready to come off. Just did a dry run of the lights with the bumper off and these suckers are bright! Will have pics up as soon as tomorrow taking that everything goes smooth.
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Whoever said that lightning would not strike twice is full of $#IT. Thanks to a bolt equipped with a Spline Drive
    which is close to the Torx drives, I have been stopped in my tracks. The Greddy FMIC bolts up directly to the bumper which is held by this satanic bolt. Once again I found myself going to autozone without a bumper to identify what this pain in my ass is and how to get it off and once again I have to track down someone with this part. Soo.. Bumper is going back on (with the HID's!!!) but without the FMIC until I find this part on Friday after work tomorrow. Good thing is that I have gotten enough practice in taking this bumper off that I can virtually do it in 5 minutes. Until then I will wax on and wax off until I see the desired results.
    PS- A cool thing that I just realized is that without my duel intercoolers in place, I will have ample room to install a true cold air intake. This system would be able to take advantage of the duct that would direct air right into it while being enough up in the bumper that I will not need to worry much about drenching it in rain due to it sitting behind the fog light housing. FUN FUN!!
    Senior Member Three Rings tdavit's Avatar
    Aug 27 2005
    CT, FL
    you can get that tool at any bike shop its a rear cogset tool
