Results 1 to 17 of 17
    Registered Member Two Rings ComfortRacing's Avatar
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    Question ko4 program question about apr 1+
    i am getting my car back tomorrow with my manifold, tp, and ko4 installed. i will drive the car up to NGP saturday to get the apr ko4 program installed but before then i will be running the ko4 on the 1+ program. is this ok, i dont want to screw something up. it is a 2 hour drive to the shop. should i not boost it till the programming is done?
    2002 A4 Quattro 5-speed, KO4, SPP Ported/Polished Turbo Manifold, ATP test pipe, APR ko4 tuning, APR injectors, APR R1 DV, Front mount intercooler, H&R sport springs/Bilstein sport shocks, Neuspeed snubber mount K&N, Blackedout grille, Badgeless rear.
    To Do's:
    -APR Sport exhaust
    -Porsche seats, brakes and wheels
    -Recarro Baby seat =)
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Re: ko4 program question about apr 1+
    No personal experience but I've come across threads where people say they are running the K04 on the K03 software without harming anything. It just doesn't operate at peak.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    yeah but 1+ has some high boost so i was concerned...i think i may just take it easy till then (sucks)
    To Do's:
    -APR Sport exhaust
    Feb 17 2005
    Sarasota, FL
    It will spike pretty high (27psi or so) with the 1+ software, just take it easy on the boost until you get it flashed
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    OK, THANKS. what's the boost on the ko4 program from apr...i looked on their site but saw no charts for it.
    To Do's:
    -APR Sport exhaust
    Jan 10 2007
    VA
    stay off the boost. switch it to stock mode if you want to be safe.
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    how much more power do you typically see going from the 1+ to the k04 + software? Is it worth the money?
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    with a turbo upgrade, yes it is worth it.
    To Do's:
    -APR Sport exhaust
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Quote Originally Posted by b6onboost View Post
    i ran 1+ all the way from CT to Maryland i kept it in stock mode. If you stay out of boost you will be fine.
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    ok, thanks guys. how do you switch to stock mode again...never done it.
    To Do's:
    -APR Sport exhaust
    Feb 20 2007
    ct
    Where you supplied with the stock program?
    Its done by holding down the cruise control for a number of seconds and the number of times the CEL flashes per second is related to a certain program (ie in my case one flash per second is Stock mode, two is 93, 3 is vallet and 4 is 100 octane). Your Apr dealer should of shown you this, its quite easy.
    Veteran Member Three Rings AudiAdi's Avatar
    Jul 06 2007
    2020 Toyota 4Runner TRD PRO || 2016 Honda Pilot Elite AWD
    Bellevue, WA
    unless he didn't get the "stock" program
    USP CLUB MEMBER #78
    2005 Audi A4 1.8T Quattro 6M K04 - GONE
    2010 Audi S4 S-Tronic ADS Lite
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    cool thanks, i just found the paperwork on it. yes i do have the stock program as well.
    thanks guys.
    To Do's:
    -APR Sport exhaust
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Make sure you dont WOT! If you do, you might put the car into limp mode heeh
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Apr 02 2008
    LA
    when you get it flashed please post up.... i'm curious to see if there's a big noticeable power gain over k03 1+
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    i thought there was. but it was all low end tq. honestly i kinda miss it, the GTRS doesn't have that kick you in the back seat feeling.
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    yeah i talked to the NGP Racing (the ones doing the software) and they said leave it in 93 +1 and not to get on it. they said it is less likely to get into limp than stock.
    Phantomb6 i will repost and let you know the outcome but i only had the 1+ for about and hour before i got a cel and oil pressure light came on (the sludge problem) and had to get it home gingerly. so no real feel for it from the stage 1 program i just had upgraded that day. also, i had a test pipe, and a turbo manifold installed with the turbo so it isnt a fair assesment sorry.
    To Do's:
    -APR Sport exhaust
