anyways plans for the car are as follows tune from vast with 60lb injectors, rs6 turbos with rods, valve springs, retainers, and upgraded bolts(needed?) along with a front mount with a 2in 1 out design along with upgraded fan. Also im upgrading the oil lines to bigger ones and prob will have them wrapped to keep out heat from the manis .Other things i though of doing are oil cooler(s) possibly either wrapping the exhaust manifolds with exhaust wrap or having them ceramic coated .... ill also being porting them myself. also thinking of phenolic intake spacers and the lower compression head gasket 034( i think) sells as well as having the rings and seals and sleeves all changed on the engine . another thing i thought of doing is new upgraded pistons and valves but im not sure if theyre needed. and eventually water meth in the system. if i do pistons im thinking i might port the cylinder barely just to get like a fresh start kinda like unused metal lol but if pistons aren't needed this wont happen .... anything i missed? lol
oh and what clutch should i run... i was looking at
the stage 3 vast sells but can it hold this power?
also anyone who's done this i know the price of the rods, retainers , and springs is around 1500 but what about other things like does the motor need to be rebalanced? cus i know a reputable shop to build and clean and balance it and put everything in it lol but they want 1200ish soo im not sure which route to go yet so any insight is helpful thanks!
