Results 1 to 24 of 24
Thread: Engine Cleaner
    Registered Member Two Rings
    May 28 2008
    2002 Audi A4 1.8T
    St. Louis
    Engine Cleaner
    I just bought an 02 A4 and the engine bay is pretty dirty...What is the best way to clean it up? What kind of cleaner works the best? Thanks!
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Re: Engine Cleaner
    Degreaser, a brush, and a good rinse. Don't forget to cover the air intake (if you have an open element, and any exposed electronics.
    the homebrew'd s4
    Dec 19 2007
    York, PA
    Re: Engine Cleaner
    if you can find it...automotive simple green...little more concentrated.
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    Re: Engine Cleaner
    yes, the Automotove Simple Green is good stuff.
    when its done, if you want to give it that new engine look... like you see from used car dealers... just lightly dust the engine bay with plain ole' Armor All.
    you might not want to do step 2 if you do all your own work, as it is 1 more greasy thing to deal with.
    Feb 17 2005
    Sarasota, FL
    Re: Engine Cleaner
    A clean engine bay is a happy engine bay, good luck!
    Dec 19 2007
    York, PA
    Re: Engine Cleaner
    Quote Originally Posted by EErie B6 View Post
    i cant find that shit anywhere anymore. Where do you get it?
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Engine Cleaner
    CRC makes good engine cleaning products. I use the engine/brake/throttle body cleaners all the time. Simple green does wonders though.
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Re: Engine Cleaner
    What they said... simple green works wonders. I found this stuff at Pep Boys (not sure if that's a national chain), it's called "Trim Detailer". I think it's Meguirs or however you spell that. It comes in a spray can and is always near the tire wet stuff. Spray it everywhere. It makes everything shiny and doesn't attract dirt like some of the other stuf does. Makes my bay look friggen brand new. Can't live without it so much so that I bought a case of it. I even spray it in my wheel wells and over the belly pan and all the underside plastic. It makes all the plastic trim look brand new.
    My 2004.5 APR Stage 3+ is SOLD
    Oct 31 2006
    San Antonio, TX
    Re: Engine Cleaner
    I used to mix Dawn dish soap with water, shake it up and apply using one of those hand-pumped pressure sprayers. Let is soak on a warm engine for 5-10 minutes breaking down the grease and grime, then gently spray off with a hose. I always kept the car running while rinsing off the engine as you would notice a change in revs if you were hitting electronics, wiring or intake more than you should; you could quickly back off on the spray
    Current: 2016 S6 Previous: 2015 A6, 2012 Q7 Prestige SLine, 2005 S4, 2007 Avant 2.0T, 2002 A4 1.8T
    Senior Member Three Rings jokas's Avatar
    Jun 11 2004
    2003 Audi A4 1.8T Quattro
    North Jersey
    Re: Engine Cleaner
    i've found these instructional videos to be helpful.
    http://www.adamspolishes.com/t-videos.aspx
    all products can be purchased through phil@detailersdomain on az, with of course an az discount...
    Registered Member Three Rings SlappyB6's Avatar
    May 14 2008
    W-S, NC
    Re: Engine Cleaner
    Quote Originally Posted by rxrep View Post
    I used to use Meguiar's Interior Quick Detailer on my engine bay, it may be somewhat the same thing. Worked well, not too shiny, and it wasn't real greasy. Good for the interior, too.
    *On a side note rxrep...sad day for Penguins fans. I'm originally from the Picksburgh area myself.
    02 A4 - 5spd - Sport - VM DP
    Capt. Obvious - "Not me. I fart rainbows, shit rose pedals and piss excellence."
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Re: Engine Cleaner
    Adam's In-n-Out spray is absolutely briliant! I'll first do a quick spray down with water. Then I'll use Simple Green (picked up at WalMart in the automotive section) to go after the hoses, plastic, and metalic parts. I'll let it sit for a while, then go in with a brush. I'll then rinse everything off and let dry.
    After drying, I'll blast everything in side with the in-n-out spray. Brought back like new apperance. It's just that simple. It's just that good!
    USP CLUB MEMBER #34
    May 30 2008
    Honda HRX
    Penna.
    Re: Engine Cleaner
    Quote Originally Posted by n7plus1 View Post
    AutoZone, or K-Mart... i cant remember for sure
    stuff i found was in a spray bottle, like Windex comes.... i want to say it had a gray label, with green words
    May 30 2008
    Honda HRX
    Penna.
    Re: Engine Cleaner
    hard core fan right there!
    Feb 28 2006
    Pittsburgh-Philly
    Re: Engine Cleaner
    Quote Originally Posted by SlappyB6 View Post
    Good that you escaped. I'd kill to get out of this place, and the NC area is my number one place to move to. Anyhow, it's not too sad to me on the loss. A loss to the Flyers would be sad, lol. Detroit, however, was obviously the better team this time around. I'm not a fan of winning ugly. I am a fan of winning because I'm better. And in this series, Detroit was everything better, and I can't argue that. Faster, crisper-er, better-er/faster line changes and match-ups. The only thing I'd argue that the Pens did better was goaltending, even though Ozzy did what he needed to do when it counted. But to be out-shot like 2:1 and to go 16 minutes with no shots on goal at all.... the list goes on and on. Penguins didn't play to their potential but for a few desperate shifts, and I really question their dump and chase game plan.
    I don't mind losing to Detroit, because even though some of their fans are morons (but what town doesn't have that?), their team and coach where very professional and classy. They didn't trash-talk, and didn't play dirty hockey (if anything can really be called "dirty hockey"). They didn't whine or complain; they just played their game and did it well. Hat's off to them.
    /threadjack. Sorry 'bout that. Go clean those bays, lol. And don't forget what you can see underneath, too! Just cleaning the top side is like cleaning your arms and legs but leaving your armpits and ass and 'taint all dirty. True satisfaction comes from getting up under that bitch on your back with shit dropping in your eyes, lol. Once you clean the BOTTOM side, then you truly feel you've accomplished something and aren't hiding anything.
    May 14 2008
    W-S, NC
    Re: Engine Cleaner
    Good that you escaped. I'd kill to get out of this place. Anyhow, it's not too sad to me on the loss. A loss to the Flyers would be sad, lol. Detroit, however, was obviously the better team this time around. I'm not a fan of winning ugly. I am a fan of winning because I'm better. And in this series, Detroit was everything better, and I can't argue that. Faster, crisper-er, better-er/faster line changes and match-ups. The only thing I'd argue that the Pens did better was goaltending, even though Ozzy did what he needed to do when it counted. But to be out-shot like 2:1 and to go 16 minutes with no shots on goal at all.... the list goes on and on. Penguins didn't play to their potential but for a few desperate shifts, and I really question their dump and chase game plan.
    Very good points on both accounts. I won't thread jack further, so how about some pics of some clean engine bays?
    Feb 28 2006
    Pittsburgh-Philly
    Re: Engine Cleaner
    You had to go there. Probably more proud of this stuff than any of the mechanical mods I did. Let the pic whoring begin. Someone stop him, lol...
    This one is my money shot, I think:
    And the 'taint of the car:
    This is all done with simple green, toothpicks, detail brushes, and Meguir's Spray/Trim Detailer. No expensive gotta-have shit.
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Re: Engine Cleaner
    ^^^ it's like a rainbow sticker underneath your hood
    j/k
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Dec 19 2007
    York, PA
    Re: Engine Cleaner
    i initially bought a gallon jug of it at a local autozone...went back and they no longer carry it...maybe ill have to try k-mart, i havent been there in YEARS
    May 28 2008
    2002 Audi A4 1.8T
    St. Louis
    Re: Engine Cleaner
    Thanks for all the info!! And your engine and car are CLEAN!!! Looks great.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Re: Engine Cleaner
    my engine bay is never as clean as Lee's
    god damn it
    where do you find all the time to do that shit? weekends?
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Feb 28 2006
    Pittsburgh-Philly
    Re: Engine Cleaner
    Quote Originally Posted by Maverick View Post
    Some guys golf. Some play in softball leagues. Others do fantasy football/baseball. Some play xBox all damn night. Others drink a lot. I, on the other hand... clean my car. It's an OCD thing. It's pretty much all I do. I've taken most of it apart, cleaned it, and put it back together again. I need to see a therapist.
    Don't forget though that my car isn't a daily driver. If I took pics of THAT engine bay, you'd all laugh. It's nasty. You guys that keep a DD in any sense of cleanliness (more points if you live up north... Florida people don't count, Shawn) have my vote.
    May 30 2008
    Honda HRX
    Penna.
    Re: Engine Cleaner
    you need a fresh "canvas" to work on your art... when should i drop off my car?
    May 30 2008
    Honda HRX
    Penna.
    Re: Engine Cleaner
    lol, same here, cept the last 6 months... i have been there 2x... thats right 2x, and its like a whole new world of shopping.
