    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    New (to me) B6 -- many ECU codes :-(
    Got the car (2004 B6 avant 1.8TQ auto) last week and today it stumbled a bit and the CEL came on, so I ran the codes (with a borrowed Ross-Tech VAG-COM) and got this list. Also, I could not connect to the central locking module (to reprogram the remote windows). I am checking the codes individually on this forum, but I'm wondering if the trend indicates something more common like a wiring problem, or a problem with some part of the bus. Any assistance appreciated. Thanks!
    Address 01: Engine Labels: 06B-909-518-AMB.LBL
    Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A
    Component: 1.8L R4/5VT G 0006
    Coding: 0016751
    Shop #: WSC 05146
    4 Faults Found:
    19497 - Powertrain Databus: Implausible Engine Temp. Message from Inst. Panel
    P3041 - 004 - No Signal/Communication - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded - MIL ON
    16685 - Cylinder 1: Misfire Detected
    P0301 - 001 - Upper Limit Exceeded - MIL ON
    16686 - Cylinder 2: Misfire Detected
    P0302 - 001 - Upper Limit Exceeded - MIL ON
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8E0-614-517.LBL
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04277
    Shop #: WSC 06435
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-10 - - - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1319
    Coding: 00000
    Shop #: WSC 63251
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 16: Steering wheel Labels: 8E0-953-549.LBL
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 01042
    Shop #: WSC 63251
    1 Fault Found:
    00474 - Control Module for Immobilizer
    49-10 - No Communications - Intermittent
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
    Part No: 8E0 920 950 P
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01231
    Shop #: WSC 05146
    WAUVC68E84A131268 AUZ6Z0C0346725
    4 Faults Found:
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to Plus - Intermittent
    01176 - Key
    07-10 - Signal too Low - Intermittent
    00668 - Supply Voltage Terminal 30
    53-10 - Supply Voltage Too Low - Intermittent
    01314 - Engine Control Module
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1411
    Coding: 12044
    Shop #: WSC 63251
    Part No: 8E1959801
    Component: Tõrsteuer.FS BRM 0003
    Part No: 8E1959802E
    Component: Tõrsteuer.BF BRM 0003
    Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0004
    Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0004
    7 Faults Found:
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    01573 - Alarm triggered by Door Contact Switch; Left Rear
    35-00 - -
    00955 - Key 1
    00913 - Window Regulator Switch; Front Right Driver (E81)
    27-10 - Implausible Signal - Intermittent
    Address 56: Radio Labels: 8E0-035-1xx-56.LBL
    Part No: 8E0 035 195 H
    Component: symphony II NP2 0400
    Coding: 01001
    Shop #: WSC 66560
    1 Fault Found:
    01305 - Databus for Infotainment
    37-10 - Faulty - Intermittent
    End
    Active Member Three Rings 3thrd_a_4's Avatar
    Oct 15 2006
    03 BT A4/91 GTI 2.9VR6 S/C'd
    Re: New (to me) B6 -- many ECU codes :-(
    U might have a bad coilpack. First thing you want to do is clear all the codes to see which ones are old. Any present issues will set the MIL on again or generate another code
    ReVO BT and a bunch of other stuff
    May 31 2008
    Palm Beach, FL
    I did that a few days ago, because the codes involved a lot of low voltages and I know the battery was replaced on the car last week. So these codes are new. I'm not sure why the alarm codes would be there though, as I didn't trip the alarm.
    Feb 17 2005
    Sarasota, FL
    Swap cyl 1 & 2 coilpacks with 3 & 4 and clear the codes again. If misfires come back now on 3 & 4, the coilpacks are bad, just replace them. And quite a few of those codes are from low battery voltage, you sure they were ALL cleared after the battery change?
    Veteran Member Four Rings orttauq's Avatar
    Mar 11 2007
    8V S3
    tri state
    ECT sensor seems to be faulty, which can also throw bogus misfire codes :)
