Results 1 to 21 of 21
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Exclamation Methanol Injection = Misfire. Please help me!!!
    I need some help from you guys on my Stage 2 Snow Performance MAF Methanol injection kit. Background... I am running it on a 2001 A4 1.8TQM.
    I installed the kit tonight and everything was functioning properly during my tests. I revved the car up and once the RPMs got up to about 3,400 RPM it would start spraying and hit full spray at 4,000 RPM. Then I installed the sprayer into the intake hose and filled it up with 50/50 M1 methanol & distilled water and took it out for a spin.
    First run I ran it without spraying just to make sure all was well (I put a switch in for this reason). To my surprise I bogged in first then then it felt fine throughout the gears. Then starting again (still w/out meth) my check engine started flashing and I looked in my logger to see I got a misfire on Cyl 2 & 4.
    After that, I brought the car back to the house and checked it out but nothing looks wrong (still gotta check the plugs though). I flipped on the meth just to check and to my surprise while revving the car it will not engage now.
    Here is how I set up the wiring to the brain box:
    +12v switched ign (Red wire) = 75x pole under dash (leftmost pole)
    MAF signal (Yellow wire) = Green shielded wire coming off the MAF sensor. I was told this should be the yellow one but I get absolutely NO signal from that wire at all.
    Ground (Black wire) = Chassis bolt
    Pump (Green wire) = Red wire coming off the pump (and the pump's black ground wire is grounded to a chassis bolt)
    Please help. I don't want to break down on the way to work tomorrow.
    Feb 27 2005
    North Wales, PA
    Re: Methanol Injection = Misfire. Please help me!!!
    check your wiring again and make sure the connections are solid. Then check your fuses and maf. I have a feeling you blew the maf.
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by Poopie View Post
    I am going to wake up early tomorrow before work so I can check my connections & plugs. What do you mean by blew my MAF? You mean toasted like I need to buy a new one?
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    almost positive it's because youre spraying too much meth too early. dont set it by RPM set it to trigger at a certain boost level. if youre spraying at 4000 at 1/4 throttle you will run extremely rich and misfire
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by GetBoosted84 View Post
    perhaps. Mafs are usually the culprits of misfires. I'll check into the wiring diagram tomorrow. Kevin has my manual
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by AudiRacerS4 View Post
    His is set by maf readings. If you are at a high rpm but very little throttle angle you are pulling very few g's from the maf so it won't spray meth.
    Oct 28 2006
    thats true too but i had the exact same problem as him when i was spraying too early
    Apr 10 2007
    Eastern PA
    Ok, I just got in from looking at the car and here are my findings:
    All the plugs look ok. There is a slign black spot on 3 of them towards the side though but overall they look to be in good working order.
    I think my LED burnt out (wires are all good running to it from the brief look I took) so I cannot tell exactly when the pump is turning on. I am going to replace that today to see if that's what the issue is.
    The brain box is getting power from both the MAF (yellow) wire and the +12v Switched Ign (Red) wire. What I did also do was re-set the knobs on the brain box. Before they were a little lower than what I changed them to. Here is what they are set at currently:
    Start of Spray (left knob): ~ 2.5v
    Full Spray (right knob): ~ 3.0v
    For now I have dis-engaged the system just to be safe until I can get this worked out.
    What else should I be looking at? Maybe it's something stupid like the spray voltages I set being incorrect.
    Dec 05 2007
    If you need a MAF, I have an extra one from my 01. I replaced mine 2 weeks ago along with my 02 sesnors because I was not liking my gas mileage. It is not shot, but I do not know the full condition of it. I just replaced it because my gas mileage was ~19 mpg. No CEL but I never logged it. I replaced all 3 (both 02 sensors and MAF) to make sure I would get better gas mileage (yes, it worked). But yeah, if you want it it is yours. Just pay for shipping. PM me if you want it.
    Apr 10 2007
    Eastern PA
    Thank you very much for the offer. Unfortunately I need to run a 3" 225 TT MAF for my k04 application.
    Dec 05 2007
    No problem
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Does you MAF use just a TT housing or TT housiong and sensor? You can probably use the sensor and swap in into your larger housing. I have one too if you want, just pay shipping (it didn't get best readings but no misfiring).
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by nebone22 View Post
    I'm running the 225TT sensor and 3" 225TT housing currently since the Hammer file requires that.
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    I'm running the same system as you and your start and full on voltages are too low. Try a start voltage of 3.0 and full-on at 4.8/5. Also be sure that your aiming the correct thing. I was confused at first but after talking to Snow I figured it out. On my controller there is a little red dot next to one of the "cross-hairs/philips". Originally I was aiming the red dot, however I found out that your supposed to aim the cross-hair that the red-dot is up against (I hope this makes sense).
    Some fast things and some slow things
    ~Josh~
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by mtbrider View Post
    Oh, that might be my issue. I'll check it at lunch time. I was having the same issue trying to tune this thing. I didn't see the little red dot.
    Apr 10 2007
    Eastern PA
    Ok, I think I jumped to conclusions. After replacing the bulb (which did burn out btw) and changing the start voltage to ~3.0 volts and my full spray voltage to ~4.9 volts I re-ran the car and let it idle and I am seeing zero misfires. In addition, I VAG'd the car and I am seeing no codes and no timing is getting pulled.
    I will post up my before and after timing logs once I pull the data in from my laptop.
    Thanks again guys for all your help!
    Veteran Member Three Rings B5Burn's Avatar
    Feb 25 2007
    1998.5 A4 2.0BT
    Winnipeg, Manitoba Canada
    So she's good now??
    B.
    Apr 10 2007
    Eastern PA
    Yeah everything is looking solid now. Actually the car feels stronger when doing a pull in 2nd and 3rd. I'm not sure if it's just me or if it is really pulling harder. It should pull harder yet once I play with the timing a little bit.
    Feb 25 2007
    1998.5 A4 2.0BT
    Fantastic, I had an epic troubleshoot this week also, good stuff! Congrats.
    B.
    Oct 28 2006
    do you have the stage 2 meth kit? if so why dont you run it off the MAP instead of MAF signal its much easier to tune and tweak that way
    Apr 10 2007
    Eastern PA
    The MAF setup allows for you to fine tune the meth setup regardless of boost which is what I am looking for. Basically the MAP setup is less precise than the MAF setup.
