Results 1 to 21 of 21
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    To Shave or Not to Shave..
    iv got my stock a4 bumper off all sanded down and ready for primer+paint(some asshole hit me and i was stupid enough to not make a police report)... but i was just thinking to maybe shave the washer nozles in the bumper? mine dont work anyway so its not like id be losing anything over it? whats everyones opinion? car is santorin blue btw, thanks
    2004 Subaru Impreza WRX
    Aspen White
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Re: To Shave or Not to Shave..
    shave em', it will look much cleaner.
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    shave them and take the whole system out so you dont have to drain your windshield wiper fluid every time you want to take off your bumper
    ::2002 S6
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Quote Originally Posted by TQMB5 View Post
    ^^ what he said. Mine is gone and his is too. If you really want to go all out then drop the 40 bucks to replace the washer tank with the non-headlight washer one. It is the same but doesn't have the hole in the bottom.
    Jim
    I Do Werk.
    Feb 09 2007
    00 S4
    MA
    definitely shave the nastiness down in front....the girls love it.
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Senior Member Three Rings LowSantorin's Avatar
    Oct 19 2007
    Dub State
    shaved for pleasure!
    Dec 14 2006
    Halifax, NS, Canada
    washers are awesome!! fix them!!
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I just removed mine, and I didn't lose any more fluid than that which was in the washer lines.... granted I haven't used my washers either since then.
    I'd say shave 'em. It looks good without them.
    Veteran Member Four Rings SurferForever's Avatar
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    go do work
    Natasha: 01 A4 2.0 T28/T04 || Silver (Fastest Color)
    034 Motor and Tranny Mounts | Full 3" exhaust with HFC | APR Snub | B&M Short Shifter | APR Boost Gage | RS4 Grill w/ Custom Matched Lowers | 8000k Headlights | 3000K Fogs | M3 Lip Spoiler | Reiger Roof Spoiler | Debadged | Clear Corner Mod | Independent Fogs | Dual Rear Fogs | Zimmerman Cross-Drilled Rotors | Mintex Pads | SS Braided Lines | 18X8 Black ASA AR1's
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    i was told at least ppl who have snow in their area - those do come in handy - but if you are in a dry place like i am - you would want to shave them off as they pretty much do nothing
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    It snows in my area, I handle that situation with brushing off my damn car. Yea, they're cool to show off the Honda people that don't understand luxury options, BUT they more annoy me than prove functional.
    By the time I'm done doing that I have heat, and my seat heater is blazing.
    Aug 13 2007
    what exactly would i use to fill it? what would i use to re-enforce in behind the bumper?
    Aspen White
    Sep 11 2007
    Dirty Jersey
    you know if you take the washer fluid hose and quickly point and hold it upward after disconnecting it you loose a very small amount of fluid
    personaly I tuck mine in the rad support when the bumper is off
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    same, you dont lose alot of fluid.
    and also, they spray your hood more than your lights, lose em.
    Aug 13 2007
    Quote Originally Posted by BONFIRE074 View Post
    took out the system today from the bumper, but need help with this, thanks
    Aspen White
    Mar 09 2004
    nw michigan.
    Kitty Hair or Duraglass with body filler to finish it off.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    Quote Originally Posted by aytheory View Post
    There was only one day last year that I could have used them but it was daylight so it wouldn't have mattered anyway. It would have taken a half minute to jump out and break the ice off them.
    That ice on the lights is more than 1/4" thick. More than 1/2" in some places.
    Jim
    I Do Werk.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by onemoremile View Post
    Just use the kitty hair so it fills in more then just the hole and then sand it down. Try to use no or very little body filler since it can crack.
    Mar 09 2004
    nw michigan.
    Good point. TQMB5 and I just did his. Keep the glass relatively thin. Lots of thin layers will resist cracking much better than a thick one. It will also keep it from shrinking in the curing oven which may crack the paint. Mine has a hairline crack part way around both openings.
    Jim
    I Do Werk.
    Veteran Member Four Rings loustylez's Avatar
    Oct 03 2006
    2001 A4 2.8 QT
    kansas city
    when filling these holes and such, does the whole bumper need to be resprayed or just the portions you fill in and around it. i'm assuming any paint work like this, it's best to sand down the whole bumper and respray the whole thing? or are they able to blend it in.
    Mar 09 2004
    nw michigan.
    Small areas can sometimes be blended but for a part like this it will be easier and quicker to prep and paint the whole thing. Blending is usually reserved for unibody damage like a dented rear fender.
    Jim
    I Do Werk.
