    Established Member Two Rings STaSIS_2.0T's Avatar
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    Hardwiring my 8500... anyone know the part number for the OEM momentary dash switch?
    Want to hardwire my 8500... anyone know the part number for the OEM momentary dash switch?
    STaSIS/GIAC ECU | ITG ProFilter | EvolutionRacewerks SMIC's | STaSIS exhaust | STaSIS/Koni/Vogtland suspension | STaSIS/Alcon 355mm Mono4 brakes | Volk CE-28 19x8.5 | Toyo T1-R 265/30 | O.Z. Superturismo GT 18x8 | Dunlop Wintersport 3D 235/40 | JHM short shift kit | ECS snub | RS4 rear sway | RS4 pedals | S4 shift knob | RS4 grill w/s-line chrome surround | VMR vent boost gauge | 034 Intake Pipe | CoolBoxMod | Hardwired 8500 X50 w/"OEM" mute button |
    Jul 11 2005
    NorCal
    Re: Hardwiring my 8500... anyone know the part number for the OEM momentary dash swit
    what is 8500?
    B7 Manual Quattro - Quartz Gray - Sport Suspension
    Neuspeed SS/Exhuast | APR Snub Mount | 12" Sub | Hoen Fog Lights | Rear Spoiler |RS4 Sway Bar | APR Intake/Chip
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    sorry... passport 8500 X50 radar detector
    Veteran Member Four Rings TSlice's Avatar
    May 18 2007
    Houston
    Quote Originally Posted by TSlice View Post
    I used this DIY to do the OEM mute button/LED alert: http://www.audiworld.com/tech/elec156.shtml . The only difference is that since the DIY is for an A3, you will use a different button since the dash is different. I used part number 8E0 035 775 D 5PR which is a blank faced version of the 'FUNK' radio button seen elsewhere. You will also need the terminal plug, part number 4D0 971 636 B and two repair wires, Part Number 000 979 009 to make a harness that will plug into the back of the mute button. Obviously, the part number for the mute button will be different depending on if you want it with the chrome strip or the black strip. I don't have the part number for the blank face switch with the black strip, but I have ETKA and can get it if anyone needs it. My local dealer said he was unable to order this button since it was not in his system, so you may have to order it from OEMpl.us or VAG Parts. Also, inside the mute button DIY there is a link to an article on how to change the LED inside the button from green to red, but I chose to leave mine green so it would be more noticeable against the red dash lights, but you can do as you please. Hope this helps.
    Found with a simple search, and this was discussed just a few days ago. Sheesh!
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    Perfect! Thanks!
