Results 1 to 9 of 9
    Senior Member Two Rings Betty1.8T's Avatar
    Feb 12 2008
    2001 Audi 1.8T
    San Jose, Ca
    Question What Do You guys think about using STP Gas Treatment?
    What Do You guys think about using STP Gas Treatment for a 2001 Audi A4. I want to be able to save "some" money I guess. Will I run into problems?
    Dec 14 2006
    Halifax, NS, Canada
    Re: What Do You guys think about using STP Gas Treatment?
    I have a fifth gear episode where they did tests on a bunch of these including the STP. They noticed a decrease in power about 3% (they used a dyno) and lower fuel economy. They had 3 cars. 1 STI, a Clio i think, and i cant remember the last one.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Feb 12 2008
    2001 Audi 1.8T
    San Jose, Ca
    These tests are where they constantly use them when they fill up? So Im guessing that's a no.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by Betty1.8T View Post
    You won't save money. Lucas is good for cleaning the fuel system, but thats it. These cars get decent milage to begin with, if you want to save money then WALK or take PUBLIC TRANSPORTATION
    Feb 12 2008
    2001 Audi 1.8T
    San Jose, Ca
    Thanks.
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    Quote Originally Posted by bassed View Post
    i use the lucas stuff every oil change, just buy the big jug and fill enough to treat one tank. with the cleaner in the system its not going to make power, its got heavy detergents that attempt to clean the spray nozzle to bring back the oem spray pattern supposedly. those detergents dont produce hp, the "hp" if you gain if any come from after the cleaner has done its job and restored or improved injector performance and any dirt in nozzle. if you rely on those 10 dollar NOS/outlaw/ect products to give you 3-10whp (what they claim) than you might as well invest in different options.
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Don't waste your money.
    Any fuel system cleaner is only going to add alcohol and detergents to your fuel. The added alcohol has been known to eat away at the diaphram in fuel pressure regulators.
    use quality fuel, and it'll take care of itself. You want more proof look into all the issues people have when switching to E85.
    Jun 04 2004
    fairfield cnty, CT
    Quote Originally Posted by djwimbo View Post
    what? most cleaners use naptha and a combination of other gasoline solvent derivatives.
    to Betty1.8T , you should periodically use a fuel system cleaner/injector cleaner like techron or seafoam. Like every other oil change.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    More like every 20k miles or when it feels like it needs it. Spending more money on ancillary products won't save money on fuel. What will save money is keeping the tires at 36-40 psi, a good alignment (can't overstate how critical this is to mpg), and keeping the engine in good running order. That usually means a clean air filter, good spark plugs, and no malfunctions.
    Jim
    I Do Werk.
