OK, here's my story. (cliffnotes at the bottom)
I got my A4 about a month or two ago which has a "Stage 3, 8-panel unorthodox racing clutch" and a lightweight 11lb aluminum flywheel in it. It was changed roughly 30k miles ago.
Admittedly, this is my first manual transmission car that I've owned, but not the first I've driven. Prior to owning the A4, I learned on abot 3 cars and drove a Mk3 Jetta around for a week or two.
When I testdrove the car, everything felt great. The clutch engaged very smoothly except I noticed it was a little high. I've been told Audi clutches are relatively high so I didn't fret over it.
I'm not bad at working the clutch/gears but obviously I'm no pro. I asked a friend to teach me how to take off quickly (like off a line, to race). We spent a couple hours in the middle of night practicing, moving spots when kicked out, practicing some more, etc.
The next morning, I turned the car on while in neutral and heard a strange chattering sound. I pushed the clutch in, let it back out and the sound was gone. I noticed something off about engagement. It was either jerky or shuddering but this went away after 2 days. Now the clutch just shudders a bit when engaging into first from a dead stop. I've noticed that the engagement point has moved back a bit, as well.
So a day or two after the chattering, I took it to my local shop where they took a spin around the block. The tech said that the engagement point did feel a bit high and it's a sign of the clutch going out. I asked for clutch recommendations and he said Southbend is pretty good for OEM/Stage1.
Cliffnotes:
30k old Stage 3 clutch in car when I got it
Some launch-learning didn't treat it well
Now it's going out. (Shuddering while engaging into first, engagement point receding)
Which brings me to my questions:
Which clutch should I get? I'm too poor right now to go BT, so really I just need something that will be durable, and engage smoothly. I want to be able to rev up and drop the clutch every once in a while without it destroying something and it also needs to take the small amount of abuse that comes from me learning the subtelties now.
Secondly, do you think I'll need to change the flywheel, and how much should the entire job run me (parts and labor seperated).
Thanks a lot!
