Results 1 to 9 of 9
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Need a good 12v connection
    Hey guys I need a good 12v connection that is good to tap into for when the parking and headlights turn on. I tapped my gauge into my vent wiring and it makes my gauge pulse. I already have my constant on the x75 but I need a good source for my dimmer feature thanks
    2010 Brilliant Black/Magma Red S4
    Jan 14 2008
    Carlisle, PA
    Re: Need a good 12v connection
    bump
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    I usally tap into the ignition wire, but for when you lights turn on why don't you just use the parking light or headlight fuse?
    Jan 14 2008
    Carlisle, PA
    Quote Originally Posted by Allaidback View Post
    Which fuse is the headlight/ parklight's? and do i just get a connector pinched in between the fuse?
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    you can just shove the wire in with the fuse on the fused side, kinda ghetto but it works (good for a boost guage) other than that the parking lights you have to tap off the headlight stalk, not a fun one to get to.
    Jan 14 2008
    Carlisle, PA
    Quote Originally Posted by infinkc View Post
    haha yeah I had pretty much all of it apart but then stopped because I didnt want to break anything, so I tapped into the vent lighting but that's not supplying a stable enough current. which number is the headlight fuse? and is this safe for the long term
    Jan 14 2008
    Carlisle, PA
    bump
    Jan 14 2008
    Carlisle, PA
    bump does anyone know which fuse the headlight/parking lights are?
    Dec 06 2007
    Calgary, AB, Canada
    Or you can tap into the cig. lighter backlighting wire.
    The fuse is easier though. Check the fuse box panel, that tells you which fuse is for what.
