Results 1 to 12 of 12
    Registered Member Four Rings A4 ABT's Avatar
    Feb 23 2004
    03 A4 1.8T Quattro
    Sunshine state
    Car sounds like a TDi after test pipe install?!?
    I had an ER test pipe installed last Friday. Since then, the turbo sounds like a TDi turbo. It still boosts normally, but the vacuum is at ~12 at idle as opposed to ~18 before test pipe install.
    Should I be worried about that TDi sound? If so, what should be checked?
    Thanks for your help
    '03 A4 1.8t Quattro
    Exterior:USP front w/ Kerscher splitter--ABT sides--Votex rear--S4 trunk spoiler--S4 Door Blades--Euro blindspot mirrors--19" ACE Klassik
    Brakes/Susp.:NS rear swaybar--Audi Sport Suspension--NS brakelines--ECS OEM 3.0L brakes--Hawk pads
    Engine:GIAC K04--Genesis 380cc injectors--Okada CP--AWE Tuning FMIC--APR stealth exhaust--ER Test Pipe--Carbonio V2--Forge Splitter--Forge TIP--NS snub mount--ECS Stage 3 Clutch
    Interior:AWE Tuning Boost Gauge
    Buncha motorcycles
    Memphis, TN
    Re: Car sounds like a TDi after tet pipe install?!?
    something must not be tight
    APR Stage 2/AWE Intake
    Feb 23 2004
    03 A4 1.8T Quattro
    Sunshine state
    you mean it could be an exhaust leak from the test pipe installation?
    '03 A4 1.8t Quattro
    Buncha motorcycles
    Memphis, TN
    Re: Car sounds like a TDi after test pipe install?!?
    yes, did u use a new gasket?
    Feb 23 2004
    03 A4 1.8T Quattro
    Sunshine state
    I didn't do the install myself, I'll have to ask him to check his job! Thanks for your help, hopefully it'll just be a small leak
    '03 A4 1.8t Quattro
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Tight like a tiger... I hate exhaust leaks, hopefully it just needs a little torque...
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    ^^ yeah, lets hope the test pipe doesn't have a crack in it.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Feb 23 2004
    03 A4 1.8T Quattro
    Sunshine state
    Quote Originally Posted by manhertm View Post
    not supposed to...I carefully inspected it when I received it from UPS.
    '03 A4 1.8t Quattro
    Saint Cloud, Fl
    Yah it's an exhaust leak, I have one as we speak. My car sounds like ass
    instagram ------------> low_enforcement
    Feb 23 2004
    03 A4 1.8T Quattro
    Sunshine state
    thank you all for your help!
    I also had a Forge Splitter installed at the same time, it sound great! I left it in "hybrid" mode, so no major "BPV" sound, but still sweet!
    '03 A4 1.8t Quattro
    Veteran Member Three Rings POPO's Avatar
    Feb 02 2008
    2001 Chevy Tahoe, 2005 Audi A4, RIP 2003 Audi A4
    Somerset, NJ
    I have the same problem but it seems to sound worse at mid range rpms. Best way to describe is it sounds like a weed wacker string hitting a metal pole or wooden fence...high pitched "tat tat tat" until about 5k then it goes away. Any thoughts?
    2005 A4 2.0L Stroker- New South Vent Gauge|034 RSB|2.75" FMIC|GHL 2.5" Catback|PSi Concepts TD05H-20g|PSi Concepts Exhaust Manifold|Turbo XS EWG|Motoza tuned|
    RIP 2003 A4 1.8TQM
    Nov 06 2007
    B6 A4 1.8T MQ, B7 A4 2.0t MQ, B8 A4 Avant 2.0T K04
    I had a similar TDi sound coming from my B6 and it ended up being the cam chain tensioner. I'm not trying to scare you guys but it won't hurt to check it out. Especially if it seems to go away at higher RPM's.
    Mine ended up sounding like there was a midget under the hood hitting the firewall with a hammer on a drive through LA traffic. No fun!!!
