Results 1 to 7 of 7
    Nov 23 2006
    "I'LL SHOW YE GARAGE!"
    Soooouuullllll Cal!
    I know for sure that our car only take 4.4 qrts of oil.
    So I finally did an oil change (been a long time). I put 4.4 qrts of oil, check the level, and it oil was within the top line. Then I started the car and let the oil run through the engine for a minute. So after I turn it off and check the level again. To my surprise it was empty. I thought okay, maybe the oil is slowly coming down into oil pan.
    So I waited.....for like 10 mins. And I checked it again...empty. So with panic in my mind, I put the remaining qrt (5 bottle, btw) of oil. Checked it again; it touch the low line. I put the last bottle of oil and the reading showed the oil level was on the top line.
    So I run the car again and check the dipstick: the oil was fine.
    The oil I was using was Mobil 0/40 Syn.
    So I'm guessing the 4.4 qrts of oil burned quickly or something else happen?
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 10 2004
    east bay, CA
    Re: I know for sure that our car only take 4.4 qrts of oil.
    seems weird to me. i helped a friend with an oil change, and it was perfect, at about 4.5 qts.
    - Benny
    Dec 19 2007
    York, PA
    you should be waiting longer for the oil to fully drain back into the pan
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Did you fill your oil filter with oil before putting it on? The filter holds about 3/4 of a quart.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Feb 17 2005
    Sarasota, FL
    Should take damn near 5 qts with the oversized oil filter required on our cars
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    yeah, with the big kuhuna, mine takes just under 5 quarts
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Feb 17 2008
    Mine seems to take 4 and 1/4 quarts with the mobil 1 filter. I always check my oil cold just before the car is started for the day. Put the correct amount in, no need to check right away.
    02 Audi A4 1.8T Dolphin Grey Pearl 5 speed Retro Solutions HID Podi boost gauge Stern snub
    92 Mustang LX 347 stroker
