Results 1 to 14 of 14
Thread: Break Pedal
    Apr 23 2008
    Orange County, CA
    Break Pedal
    Can someone please explain to me why the break paddle is leveled so much higher than the gas? is it like that in all audis?
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: Break Pedal
    um do you have an auto? manual? i drive a manual and my pedal is fine.
    The usual things!!
    Resistor Install
    Apr 23 2008
    Orange County, CA
    Re: Break Pedal
    Quote Originally Posted by cstarky15 View Post
    Yes. I have auto.
    Active Member Four Rings 3.2some's Avatar
    Dec 19 2007
    ..is full of crap I dont need
    Escondido, CA
    Re: Break Pedal
    mine's the same height
    V/R -Phil
    B7 2006 Audi A4 3.2L Tip FWD Brilliant Black
    Apr 23 2008
    Orange County, CA
    Re: Break Pedal
    "leveled higher" by that i meant how it was closer to the driver than the gas pedal. It sounds like im the only one with this problem thus far :[
    Veteran Member Three Rings Josh_877's Avatar
    Aug 24 2007
    Chicago Suburbs
    Re: Break Pedal
    its a BRAKE pedal, and yes its higher than the gas pedal. like you actually have to lift your foot to press it instead of sliding it over.
    Established Member Two Rings m0nk89's Avatar
    Jun 20 2007
    A4 2.0T Q Tip
    Fremont, California
    Re: Break Pedal
    prolly cause of the old "unintended acceleration" problem with older audis, they increased the gap so that pushing both gas and brake at the same time wouldn't be possible, reducing a chance of unintended acceleration
    2007 A4 2.0T Quattro Tip
    GIAC - Milltek Exhaust - Carbonio Intake - VMR V713 - Stasis Street Sports - RS4 Sway Bar - RS4 Pedals - Angel Eyes/Blacked-Out Headlights - 20% Tint - V995 Hardwired
    Aug 24 2007
    Chicago Suburbs
    Re: Break Pedal
    Quote Originally Posted by m0nk89 View Post
    even still you can't hit the brake and gas at the same time. the car goes into a limp mode and slows down, its weird.
    Jan 20 2008
    A4 2.0T Quattro 6MT
    Bergen County, NJ
    Re: Break Pedal
    I have a manual and the gap in height between the brake and the gas is pretty big. It makes heel-toeing pretty much impossible for me.
    Jun 02 2007
    2004 cbr600 rr 1988 16V scirocco
    vancouver
    Re: Break Pedal
    x2...if you change to rs4 pedals it becomes easier to heel toe.
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Re: Break Pedal
    Easier, but is it still a pain to do heel toe?
    On my old BMW the pedals were placed perfectly for heel toeing. I simply cannot do it in this car. 4th to 3rd yes but 3rd to 2nd is not possible, I end up pressing the brake too hard and then missing the gas still.
    Veteran Member Two Rings KMHPaladin's Avatar
    Dec 12 2004
    North Jersey
    Re: Break Pedal
    If you broke your pedal you probably should fix it.
    Current: 2016 S3 Sepang Blue | 2006 Lotus Exige Storm Titanium
    Previous : 2006 A4 2.0tqm Quartz Gray | 1997 A4 2.8qm Europa Blue
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Re: Break Pedal
    Who broke what pedal?
    Ignorance is bliss.
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: Break Pedal
    Braker Braker!
    When you depress the brake (yup), it is at/near the pedal level for blips and heel-n-toe. Just learn how to do it.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
