Results 1 to 7 of 7
    Veteran Member Four Rings 'mk4-turbo's Avatar
    Oct 02 2007
    Montreal
    Question Have You Ever Had Water In The Trunk
    Opened my trunk yesterday (been raining for a couple of days) and i could hear water moving around in the trunk lid (in between the metal) moving. The trunk also smelled a little bit like humidity.
    I brought it to the dealer and they're looking into it
    Any of you guys experience this?
    Thanks
    Jun 03 2008
    Salem, OR
    Re: Have You Ever Had Water In The Trunk
    If it was a VW I would say the drains on your sunroof were plugged and water was backing up in to the spare well.
    This is *probably* the cause.
    Apr 16 2012
    Dirty Jerz
    Bringing this thread back from the dead but in my trunk where the spare tire is keeps flooding and so i wanted to know if there are any possible reasons that could cause it build up water in the first place since i dont have a sunroof ??
    Veteran Member Four Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    Quote Originally Posted by teckk View Post
    I'll bet it is your trunk seals. When it is dry, back the car out and water the truck. Just run the water all around it for a while and see if it build up in the trunk. You also can look for any cuts or pinches in the seals where it may let water in.
    If you have a garage, you can have someone sit inside with a flashlight and slowly run it around the lid, if you see any light from the outside then that is the sot(s).
    Apr 16 2012
    Dirty Jerz
    Quote Originally Posted by JPT View Post
    Ahhh makes sense ill check it out later thanks bro
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Larry... when you open your trunk do you have leaves, build up, etc where the lid closes? Check that and make sure it's clean as a whistle...
    BTW... Clifton? psshhhhhh we all know you're a brick city boy.
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    Bumping this up. I had a pool in my spare tire well in my Avant. Anybody had to change those rubber plugs? The seals are clean but they changed my trunk door on warranty last fall, so it could be that. From what ive read, if the sunroof drain are clogged, i should see water mark on the ceiling. Anybody found the exact cause?
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
