Results 1 to 8 of 8
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    UPDATE: Decided to re-do the OEM upper dash with a new process/material and this...
    Turned out excellent, much better than my original material finish that was glued on. Very happy with the end product.
    First a look at my initial mod to my dash (back in January)...
    The dash before its initial transformation.
    The underneath portion after lots of fat trimming.
    The open end piece of what is left from the defrost duct.
    After some more weight trimming.
    And now the new/old finish after a fake suede like material was glued on. The problem with this set up is it wasn’t going to look good that long. Indeed we already had to fix it once or twice.
    Now for the newer finish and some extras…
    First we plastic welded some plastic to close off the endings of the defrost duct.
    Then we used some expending foam to block off the holes that made up the original vent outlets. These were later trimmed down. You can also see that the upper surface was taped over with aluminium tape to hide the round cut outs.
    Close up of the centre vents.
    To further secure the round cut outs a thin layer of hot glue was added to bond onto the aluminium tape.
    Then two small aluminium right angles were riveted in place.
    Close up of the riveted aluminium piece.
    Finally the final product of the finished dash. Because I don’t have the pictures showing the actual process on how the material was applied, I can tell you a special black glue is first applied to the dash and then it is taken into a small paint booth where the material is sort of spray painted on.
    Close up of the finish product. It’s almost like a very short crew cut haircut, LOL.
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Re: UPDATE: Decided to re-do the OEM upper dash with a new process/material and this.
    Jet comes thru once again, good job
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    I love it...Nice work...
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Very good looking.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Established Member Two Rings shedpress's Avatar
    Feb 02 2008
    03 A4 Avant 3.0 6MT Quattro
    Christiansburg, VA
    Looks great. What's the rest of your interior look like?
    :: brian@shedpress ::
    SHEDPRESSdotCOM
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by shedpress View Post
    Like shit!
    The same people that did this dash for me are going to work on a centre console for me. Most likely we will use the OEM console to make a fiberglass duplicate that will be modified to my specs and it will not be a single pice but one that is modular for easy access. This will take a few months before we get into it. I have other priorities first.
    Also I'm going to paint most of the interior especially the roll cage in Brilliant red.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    So after ALL THAT...what was the final weight loss?
    Curious, because you seemed to take away all that weight and then just add it back on with the material, glue, foam, metal brackets, etc
    -Sami-
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    i love u
