REVO stage 1 is turned off. On the highway doing about 80 at 3000 rpm and slowly apply more gas. Boost only went up to 4 psi and stayed there even with full throttle. Let off on the gas for a moment and gave it gas again and boost went to 15 and then fell to 10 or basically normal. Also, occasionally I have also noticed as vacuum goes up to 0 boost tends to jump to 5 psi and then move higher. Seems like the n75 is not behaving. Is there a way to fix it or must one just replace it?
Part number if you have it and where is a cheap place to get one?
Thanks
