Results 1 to 16 of 16
    Jun 25 2007
    McHenry Co, IL
    2 piece to 1 piece
    Seriously considering trimming my fenders to accommodate some valeo ecodes. Has anyone had any problems with this? ie, rust, wiring problems ext... anything you could add would help. thanks
    '98 A4 Avant 2.8
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    Re: 2 piece to 1 piece
    Do it......
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    Did mine not too long ago, best visual appealing mod that ive done so far, and def. does give your car a "face lift". i was worried at first about trimming the fenders, but i just went for it and it came out good. i used the old wiring harness from my 2-piece headlights because i am too cheap to pay the $50 from ECS for the upgrade. no rust on the fenders yet, no condensation in the headlights, and overall a great mod. if i were to go back and do it again i would get e-codes instead of the oem headlights but still awesome.
    2004 Subaru Impreza WRX
    Aspen White
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Not to thread jack, but what are the options in the 2 piece or direct fit?
    In case there are any good options so you wouldn't HAVE to cut your fenders.
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    2 piece Depos, which have decent output. Definitely better than the stock two piecers! You can get them in the chrome or blacked out, they are all over ebay I think they are around $150 maybe even cheaper. I would not go with any of the other headlights sold on ebay though, I have heard that they have worse output than stock.
    I had them before I got e-codes and they made the front of the car look so much better.
    Here is a pic:
    ~Brian
    1998.5 A4 2.8QT
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Silverstreak98 View Post
    Did that come with bulbs? I already have the headlights/ballasts that I want, I don't need more. Are they H7's?
    ... I can't find any of those on eBay right now.
    Dec 11 2006
    Minnesota
    Yep they are H7 and don't come with bulbs.
    Just a quick search and I found these: CLICK
    You might be able to find them cheaper than that I'm not sure.
    ~Brian
    1998.5 A4 2.8QT
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    thanks for the link, I don't know why I couldn't find 'em.
    Dec 11 2006
    Minnesota
    I actually have a set that I could sell you, but one of the height adjustment screws on one side is broken. Not sure if it would be an easy fix cause I decided to get e-codes.
    Lmk if you're interested.
    ~Brian
    1998.5 A4 2.8QT
    May 10 2008
    PA
    http://cgi.ebay.com/ebaymotors/DEPO-...spagenameZWDVW
    would these fit a 96 a4 (mine) without having to mod the fenders?
    Veteran Member Four Rings CaSp3r9's Avatar
    Nov 30 2005
    Tools and toys
    Los Angeles, CA
    Yep, all of those two piece headlights on eBay are a direct fit for all pre-facelift B5's that came with two piece headlights stock. The only problem with cheaper headlights is they're more prone to fogging, especially in wet/humid climates. I have Depo's and have only had a problem with the passenger side corner, other than that they're perfect.
    Those black headlights are harder to pull off, but if done right you can make them look damn good. This is Aliel's car, ecodes would look tits on his car but I love how it looks with the black housings
    1998.5 A4 1.8tqms, Sold
    2006 A4 2.0tqm
    I have a VAG-COM if anyone in the Santa Monica area needs it.
    Nov 30 2005
    Tools and toys
    Los Angeles, CA
    Pair those projectors with an HID kit from vvme.com and you'll be damn glad you did it.
    2006 A4 2.0tqm
    May 10 2008
    PA
    Quote Originally Posted by CaSp3r9 View Post
    what front bumper is that?
    Veteran Member Four Rings TH85's Avatar
    Oct 02 2006
    2008 A4 2.0T
    Chicago
    you should get the valeo ecodes...i was in the same spot you are in a last year and fianlly went with it..
    i got the hid kit as well and they work awesome at night!! (I have had a few wiring issues with a blown fuse but not sure what that is all about)
    koni fsd/eibach suspension
    Active Member Four Rings Ben@SpeedBarn's Avatar
    03 A6 2.7t, 00 GTI, 76 GMC
    Pittsburgh, PA
    Yeah I cut the fenders on my 98, and it was definitley worth it! The valeos were amazing!
    May 06 2008
    minnesota
    where did he get those black headlights from? nice!!!
