Results 1 to 14 of 14
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    UPDATED: New Licence Plate Light assembly (1 works 1 doesent)
    Alright, so today i went to the dealer and picked up a new set of License Plate lights. Installed them easy enough.
    Now my problem is that one side (right) works and the left side doesent work. I need yours guys help beucase i don't know where to go from here. What can i do to trouble shoot this and what could be possible causes?
    Thanks
    01.5 A4 1.8t sport
    Veteran Member Three Rings Naudi_Mat's Avatar
    Nov 02 2007
    2008 S-Line A4
    Denver
    Re: UPDATED: New Licence Plate Light assembly (1 works 1 doesent)
    Did you try bending out the little bracket that holds the bulb?
    Registered Member Two Rings Audiman23's Avatar
    Aug 09 2007
    Audi A4
    Napa, Ca
    bend the bracket inside same happend to me when i painted my car
    Dec 14 2006
    Halifax, NS, Canada
    did u get the whole assembly?
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Nov 20 2006
    yes there is no brackets to bend this is an enitrely BRAND NEW ASSEMBLY everything is brand new! thats what i dont undersntad. I made sure it was plugged in properly and it was yet the light still doesent work. Any ideas on how i can figure out thats wrong or how i can fix this.
    Again brand new assembly, i had to take a appart the inside of the trunk and i repalced the entire assembly!
    01.5 A4 1.8t sport
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Swap the bulbs to see if it is a bad bulb or socket.
    The sockets the lights mount can be bent to hold the bulb more securely.
    Jim
    I Do Werk.
    Nov 20 2006
    check, check and check, switched the bulbs, and bent the little wire things no luck. Im pissed cuase both used to work, then both were broken, now with all new everything only one works
    01.5 A4 1.8t sport
    Nov 20 2006
    Anything?????????????????????????
    01.5 A4 1.8t sport
    Dec 14 2006
    Halifax, NS, Canada
    did you recheck the plug on the inside of trunk behind the carpeting for the light
    NOW DEAD :(
    Nov 20 2006
    yes, i havent even put the carpeting back yet. when it didnt work the first time i unpluged it, gave it a little cleaning (blowing air) and then re pluged it back in. Still didnt work
    01.5 A4 1.8t sport
    Dec 14 2006
    Halifax, NS, Canada
    try switching left and right see if it works with other housing
    NOW DEAD :(
    Nov 02 2007
    2008 S-Line A4
    Denver
    Didn't you say the old housing worked for the side that's currently out?
    If so, why not try and use the old one.
    Just a thought.
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    I had the same problem, bought new bulbs from autozone and it still didn't work, in fact both quit after installing the new bulbs. I cleaned the connections and one started working but the other wouldn't. I started looking at the factory bulbs comparing them to the aftermarket and realized the shape of the metal cap on the aftermaket bulb was shaped differently so I went to Audi bought new bulbs from them and they both worked.
    Try Audi bulbs.
    Nov 20 2006
    VICTORY!!!!!!!!!!!!!!!!!!!!!!!!
    Why wasent it working: BEucase when i bought the new ones the audi dealership decided that they didnt need to give me the bulb inside it. Dam crooks, just another reason why i hate....HATE going to any audi delaership. this was my 4-5th time going to one (Same one everythime) and i still havent had a good experience.
    Audi really needs to step up there personal!
    01.5 A4 1.8t sport
