Results 1 to 8 of 8
    Registered Member Two Rings my_01_S4's Avatar
    Jun 20 2007
    Silicon Valley, CA
    150K plus 01 b5s4. Service Intervals?
    Just curious what the upcoming intervals are and what the recommended work will be? I did a search and didn't find anything on this.
    TIA.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    Re: 150K plus 01 b5s4. Service Intervals?
    i think a new TB and WP. i would also flush the whole car
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    I wouldn't think you would need to do the timing belt if you did it already at 120k (every 60k). I would just look at what you're suppose to do at 50k and add anything that needs doing or subtract anything that doesn't.
    the homebrew'd s4
    Jun 15 2007
    i dont think most ppl do a TB job at 60, more like 70-80k. but I/we dont know when his were replaced
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Jun 20 2007
    Silicon Valley, CA
    Thanks all. I'm having the TB, WP, etc replaced while also having the coolant leak looked into (probably aux coolant pump or associated hoses).
    When you say flush are you including things like the diff fluids?
    Also, did I read correctly that the tranny fluid does not need to be replaced for the life of the car. I'm wondering what exactly they mean by "life"?
    Anything else?
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Quote Originally Posted by my_01_S4 View Post
    Anything else?
    AOA decided it was not worth changing the tranny fluid because there where so many problems after they did so. SO they recomend it as being a life long fluid. Are cars have ZF trannys in them, If you read anything about ZF trannys they recommend a tranny fluid change at 60k. On TIP trannys its very easy because we have a fill level that wil begin to pour out once its filled to the correct level. 6speeds dont, So if you dont add enough you coudl cause major damage.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Jun 20 2007
    Silicon Valley, CA
    Do you mean both the Auto and Manual are classified as ZF trannies? Mine's a manual. I'll do some searching/reading on them.
    So is there a procedure for a fluid change for it anywhere? I don't recall reading one in the DIY's on the various S4 forums.
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    why would the manual tranny's be much different then the auto's ? I've changed the front tranny fluid on my 6-spd, and there is a fuller hole just like any other transmission, you just top it off until it spews out the filler hole.
    A piece of advice for anyone doing their tranny fluids, make sure you get the filler plug off before you drain it.
    My car is fast
