Results 1 to 17 of 17
    Registered Member Two Rings lotekinc's Avatar
    Mar 12 2008
    NC
    Driveline slop and ASP Stabilizer
    After I installed a short shifter I noticed a certain amount of driveline movement. It is transferred through the shifter. It is evident when I go from acceleration to deceleration at low speed. Is this a common symptom of the B5 6spd @ 100k miles? Does the ASP driveline stabilizer reduce this? Transmission mounts maybe?
    Thanks in advance,
    Lyle
    Silver 2000 B5 S4 Mint! Giac/SX-Power catback/18" Moda R8/E43 Lip/Short Shift/
    Dec 06 2007
    Calgary, AB, Canada
    Re: Driveline slop and ASP Stabilizer
    Yes, yes, and yes.
    Mar 20 2008
    Italy
    GO with the Asp dts ;)
    I have it and it is great.
    The driveline movement is drastically reduced ;)
    Mar 12 2008
    NC
    Quote Originally Posted by andream88 View Post
    What is "DTS"? I didn't see anything on ASP website referring to "DTS". Do you have the driveline stabilizer, transmission mounts, or differential mount?
    Veteran Member Three Rings Paulyworld1432's Avatar
    Dec 07 2007
    Houston, TX
    haha DTS= Drive Train Stabilizer ;) but I would also highly recommend it
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    Yup got a AWE DTS for my A4 and it works great, reduces the slop quite a bit and makes it fell more solid. I found mine on here used for 150
    01.5 A4 1.8t sport
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Dec 06 2007
    Calgary, AB, Canada
    DTS=TSB
    drivetrain stabilizer = tranny stabilizer bar
    Feb 17 2008
    Ottawa Ont.
    unless you go with practically SOLID mounts you will always have some shifter movement on and off load. Its unavoidable with a mechanical linkage.
    I have to say the the DTS bar didnt do a whole heck of a lot.
    Dec 06 2007
    Calgary, AB, Canada
    ^^2nd the first part of this post.
    I would say that the DTS helps a LOT if you are doing aggressive launching.
    Feb 17 2008
    Ottawa Ont.
    I agree the DTS bar has its place. But it should not be considered a bandaid for the absolutly TERRIBLE stock motor, tranny, and rear diff mounts. Spend the money on those first.
    And dont waste your money on so called "RS4" mounts. Go directly to 034, ASP, etc.
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Quote Originally Posted by BastardS4 View Post
    Have you tried the polyurethane mount upgrade for your DTS?
    Mar 20 2008
    Italy
    ^^^ where to buy it?
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    http://shop.jhmotorsports.com/produc...0&productId=37
    this should help a lot. i just bought one yesterday. watch the video.
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    http://www.centralvalleyspeed.com/fo...read.php?t=143
    Parts needed:
    Energy Suspension part number 3-1108G
    2 7/16-14 allen bolts 1" in length
    Mar 20 2008
    Italy
    ^^^ Do you know if it can be used also on the AUTOSPEED DriveTrainStabilizer?
    thanks
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I have the AWE DTS and it works great. It definitely reduced the amount the shifter rocked back and forth when you get on and off the gas. The only thing you have to be careful with any DTS bar is how low you car is. My car is not that low, but if I don't take speed bumps like an old lady it scraps.
    Another great thing to clean up drive train slop is a snub mount. It's cheap not too hard to install and made a noticeable difference.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
