Results 1 to 14 of 14
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    help bleeding slave cylinder
    ok, quick back story. changed my clutch saturday, and of coarse got air in the lines. so i go to bleed my slave(which should be easy) but break off the plastice bleeder screw. D'OH! anyways, get a new slave put in last night, and today pick up a pressure bleeder and brake fluid..
    now's where im having a problem. i can't get the system to bleed out fully. and my pedal pressure is at absolutely ZERO!
    i've bled through probably a gallon of brake fluid in increments and put it back in the system. tried pumping the clutch. i've done everything i can think of. but no pedal pressure, and there still seems to be air in the lines. and i know there are no leaks..
    any idea's?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    Re: help bleeding slave cylinder
    Did you bleed the brakes too? Hows the brake pedal feel? Also how much are you bleeding out of your slave?
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STĂSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Senior Member Two Rings Scott's Avatar
    Apr 06 2005
    RS2'd 95 S-6, 06 Jetta TDI
    Fort Detrick, Maryland
    Yeah, check the brakes and also try to pump the clutch pedal a few times before opening it. Mine took a few pumps to get the initial pressure built up and then it blew out the last few bubbles.
    Proud owner of a currently not broken RS2'd 95.5 S-6! Hopefully it stays that way for a while!!
    Sep 17 2006
    SLC, UT
    well after a talk to old guy, i think im on the right path finally. i was definately going about it the wrong way. thankfully he seems to know a LOT about the inner workings of these damn audi's! but im on the search locally for a better pressure bleeder and then we'll see if getting all the air out of the system will give me my drivability back. fingers crossed!
    thanks a lot guys!
    thanks again old guy
    Current:
    Previous:
    Feb 22 2007
    Auburn, WA
    what ended up being the problem? Your bleeder not powerful enough for the slave?
    Sep 17 2006
    SLC, UT
    i just didn't have the right bleeder. mine was just a generic one found at harbor freight. it has a very small in line resevoir and does not connect to the brake/clutch fluid resevoir on the car..
    basically i was using this:
    and i need this:
    hopefully i can find one locally
    Current:
    Previous:
    Feb 22 2007
    Auburn, WA
    If you cant find that one you should be able to find one like this:
    What I use with air
    If you dont have air then yeah that motive should work well, it has to especially if Old Guy said so haha
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    What you are showing is a vacuum bleeder. Works fine for brakes but not so good for VAG clutch hydraulics. If you have successfully used one to bleed an Audi clutch you have my accolades!
    Feb 22 2007
    Auburn, WA
    haha sweet, yeah I've used it twice with no problem, maybe its due to our air compressor being set so high???
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by DeanUW View Post
    Do you block the clutch pedal up before you start? What tends to happen with a vacuum bleeder is that the clutch master cylinder piston drops slightly from the fluid vacuum and shuts off the feed port on the cylinder bore which prevents the vacuum bleeder from pulling any fluid through the system. Even with the pedal blocked up the master cylinder piston can still drop. Very frustrating.
    Feb 22 2007
    Auburn, WA
    I've never blocked up the clutch pedal only brake pedal... Interesting that you say that now you have me worried for future bleedings
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Sean, I was in the same predicamant as you were.
    I tried, literally, for two day straight trying to bleed the clutch...I tried it the pump method and the vacuum method, and just about everything else. LUCKILY, I posted up on my local forum, and a new member just so happened to have a motive power bleeder. In about 30 seconds i had a clutch pedal!
    I then bought my own power bleeder! Justbuy one, it already has come in handy for me twice
    -Sami-
    Sep 17 2006
    SLC, UT
    well in my boredom today i managed to Macgyver my pressure bleeder to work. just hooked it up backwards and blah blah... ended up getting all the air out of the system.
    BUT, it didn't fix my issue at hand like i had hoped. fuck!
    im going to contact Southbend to see what they say about it and if they don't do anything im going to lengthen the slave cylinder rod the old guy way..
    and if all else fails, the trans is coming back out. fuck!!!!!!!!!11!!!!!>!!!
    Current:
    Previous:
    Sep 17 2006
    SLC, UT
    damn. im not quick enough
    Current:
    Previous:
