Results 1 to 13 of 13
    Veteran Member Four Rings Ace's Avatar
    Nov 29 2005
    Belgium
    License plate leds, only 1 led works
    Ok so i bought some led bulbs for the license plate.
    but to my surprise only the driver side led works, the passenger side does not work.
    The bulbs are ok because i switched them and both work on the driver side.
    A regular bulb also works on the right side, so what is causing the led to not work but a regular to work?
    Senior Member Three Rings Hotel Guy's Avatar
    Oct 07 2007
    Chicago
    Re: License plate leds, only 1 led works
    You'll have to play around with the metal pieces on top of the light fixture. I had the same issue since I got my LEDs from 42DD and they were a touch longer than the OEM bulbs. But that was before they started flickering, dying and giving me bulb-out warnings everytime I drove. I switched back to OEM because of the hassle, but I wish I still had that awesome LED look when I first installed them.
    Established Member Two Rings vtecgreen's Avatar
    Jan 07 2008
    St. Louis, MO
    I had this problem a couple times - I think sometimes the LED's just dont work correctly, thats why when I order them I get like 4 extra, just so I dont have to mess with them a bunch.
    Try moving the contacts around, maybe clean them up a bit.
    03 1.8tqm All show, no go. Yet.
    6000K HID Fogs| LED License plate lights | Tint: 20% Rear / 30% Fronts | Lip Spoiler | 19x8.5 ADR M-Sports
    Veteran Member Four Rings 02silverb6's Avatar
    Nov 20 2006
    ATL, GA
    Also try switching the bulbs around not just switching sides.
    PM me if you need RNS-E installed in Atlanta area
    R.I.P 2002 Audi A4 3.0
    Veteran Member Four Rings krazyboi's Avatar
    Oct 24 2006
    NoVA
    I had the same issue on my A3....gave up. Had to order new light housing as well b/c the screws are stripped.
    Nov 29 2005
    Belgium
    i got myself a few new bulbs, but the same thing occured.
    so the contacts might be the problem?
    But from what i can tell those are all touching more then enough, why else would a normal bulb burn?
    Or could touching to much be bad also?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    LED's only work one way, so make sure the polarity is correct.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Nov 20 2006
    ATL, GA
    I have had these installed for about 2 months now with no problems...
    http://cgi.ebay.com/ebaymotors/ws/eB...m=140213762592
    Jan 16 2007
    Wetzlar
    what size resistor do you use?
    according to ebay seller 100 Ohms 10W. according to my calculations at 14V resistor disipates less than 2W (1.96W). Good rule si to use double so 5W is big enough.
    Nov 20 2006
    ATL, GA
    Quote Originally Posted by a2gtinut View Post
    I didn't use a resistor. They were good to go out of the package
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    I have no problems running these bulbs on my TT or Avant, but those cars don't have DIS for the license plate lights as far as I know. My S4 on the other hand can't run the 42DD LEDs without throwing a failed bulb warning.
    I keep waiting for a guy in the B7 forum to post a how-to about installing in line resistors so that I can use the LEDs for my S4.
    Now, if there are bulbs I can buy that won't need the additional resistors that would be great!
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Nov 29 2005
    Belgium
    thanks for the tip, never knew there was a polarity on those leds.
    Jan 16 2007
    Wetzlar
    I have early '04. I just tested light warning. After removing one of the bulbs I did not get any warning.
