Results 1 to 10 of 10
    Mar 20 2008
    Italy
    Snub Mount: APR or 034 with bracket?
    I've tried to search for already existing topics, but the informations are so confused!!
    I already have an APR one ready to go on the car, but i'm going to buy the phenolic spacers from 034 and thinking to change also the Snub Mount.
    Let me know what do you think
    thanks
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Snub Mount: APR or 034 with bracket?
    Well I can give a good review that the 034 one with the bracket is a great upgrade. The shifts go into the gear easier when driving since there isn't as much slop. I would say go for the 034 one all the way. Im sure others will agree
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    034 all the way. Do it.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    I've had the 034 one with bracket, and one from PureMS (Stern). The 034 one stops nearly all the movement, the Stern one worked great also, but since it doesn't come with the bracket there is still some room for the mount to move around.
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    034!
    :D
    send me a PM if you need one to accompany some 034 mounts
    Mar 20 2008
    Italy
    I have stock rs4 mounts all over with 45'000 miles on them.
    Do you think it's time to change them?
    Veteran Member Three Rings Ianxcom's Avatar
    Jul 30 2008
    Socal/Denver
    What is a good street combo with no added vibration?
    DTS + Stern Snub mount?
    DTS + 034 Snub and bracket?
    I guess im just concerned if the bracket adds vibration or not.
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Ive got the 034 SM and bracket. Just waiting to get it on.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    If you already have an APR snub mount it's not worth changing to the 034. I doubt you'll notice a difference. I have an APR snub mount and it has worked great. Get 034 motor and tranny mount if you want to get something. They are great products.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Vast snub, RS4 engine and trans mounts I run and they work well for me with stg 3 power
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
