Results 1 to 26 of 26
    Nov 12 2007
    Stamford, CT
    Do you downshift to first gear?
    This question is directed more to those with MT cars, but since I recently drove a brand new A4 with 'waffle-fry'-flippers and downshifted to 1st once in a while, I'd like to hear from y'all.
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Re: Do you downshift to first gear?
    well, unless i am in reverse, i can't upshift to 1st.
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    It depends on how low of speed I am. In traffic, occasionally I will have to use first from a slow, and I mean SLOW, roll. In traffic with the A\C on when it's 90+ degrees the car won't pick up very well from 2nd gear.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Established Member Two Rings Jagaer's Avatar
    Sep 30 2007
    2001 VW Passat 1.8T
    No, in normal traffic I usually downshift to 3rd and then use the brakes.
    If the traffic is moving slowly I do downshift from 3rd to 2nd, but that is the exception.
    I have never downshifted from 2nd to 1st. I've only ever used first to start moving, to stop clutch in at 2nd or 3rd then brakes.
    (All those habits go out the window when on the track)
    I own a budget Audi...VW. Anyone want to give donations?
    Senior Member Three Rings kelticslob's Avatar
    Dec 08 2005
    Ontario
    The only time I'll downshift to 1st while moving is if I'm going uphill and 2nd gear wont cut it. If you're downshifting to 1st to save the brakes/MPG you're wasting your time.
    2000 1.8TQM: APR 93 Chip; 710N; Clear Corners; H&R sport/Bilsteins; Piano black trim; modified S4 front; 18" B7 RS4 rims/ Bridgestone Potenza S-03 Pole Positions
    2001 1.8TQS - stock
    Account Terminated Four Rings Gundem's Avatar
    Nov 08 2005
    A4 2.8 Type-S(low)
    Los Angeles, CA
    uphill only.
    Veteran Member Three Rings dsq's Avatar
    Aug 10 2007
    B6 1.8TQM
    toronto
    i can't downshift from second to first unless i'm nearly stopped, i don't want to force it and jam it into first and risk breaking something. is something wrong with my gearbox?
    | bbs | vogtland | giac | racetec | alcon | and more |
    in the rare event of an erection lasting more than 4 hours, seek immediate medical help to avoid long-term injury.
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Quote Originally Posted by dsq View Post
    No
    Active Member Four Rings
    Oct 12 2006
    2000 Nogaro S4
    Hillsboro OR
    if comin to light in 3rd, ill take it out of gear, and coast to a stop. if im comin up on a corner, i may downshift to second if its needed, but only if there is a hill...
    now if im out in the coutry ill drive a lil more "spirited"
    2002 A4 - sold
    1990 CQ - sold (sadly)
    2000 S4 - sold (sadly-er)
    currently audiless
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    I do, but only if i'm in a parking lot going about 3 miles per hour, or if i'm on a dirt road and i want to go really slow so my car doesn't get dusty
    {99.5 Avant}
    Oct 12 2006
    2000 Nogaro S4
    Hillsboro OR
    i have friends (honda/subie people) that OBSESIVELY downshift through EVERY gear at EVERY stop....and its kinda annoying.
    if they are in 5th, they will go through alllll gears, even first, before they stop. i cant think of a reason to do that...
    2002 A4 - sold
    currently audiless
    Nov 12 2007
    Stamford, CT
    I will almost always ds if I am approaching a light. If I expect the light to change to green, I might hit 1st gear.
    The time I use it most is when people are tailgating me. There are few things I hate more. I will throw it into 1st and let out the clutch. It creates quite a panic in the ass behind me. They will always back off.
    Oct 17 2004
    Columbia, SC
    Quote Originally Posted by smithm5 View Post
    if i engine brake i always use 3rd, never use 2nd, and only use 4th if i am really high speeds.
    i now a few of those types as well.
    Veteran Member Four Rings OpenSkye's Avatar
    May 21 2004
    car parts
    nova
    i downshift to second, and roll into first if im almost stopped..
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    It's not even possible to go into first if you are moving. You have to be going reaaaaaly slow to do it.
    I don't see the point, 2nd gear has enough power to pull when you are going slow. Unless you are driving a sub 100hp dodge colt or something, then I would see the need to use 1st.
    Nov 20 2007
    2005 s2k
    So.Cal
    I downshift to 1st from force of habit, always have. I get into 1st below 20mph.
    O'Rly?
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    blip the throttle and you can downshift from 2nd to first gear. Its all about teh heel-toe baby LOL
    another stereotypical Audi
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    LA
    Usually on the streets, i only downshift to 3rd to about 25mph and then throw it in neutral and brake, but sometimes ill downshift to 2nd, never 1st though.
    (Ka-La-Bre-Ah)
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    never
    the homebrew'd s4
    Orange County, CA
    I never downshift to 1st.. ever. Only from a stop. There isnt any point because you can start from 2nd if you want to, and 2nd will let you go slow enough 99% of the time, or atleast in my case. Plus, I feel like it puts a bit more unnecessary strain on the car downshifting to first because its not nearly as smooth to do it as any other gear. I just dont see a point... even after having mastered rev matching, heel toe, etc.
    B5 Parts For Sale
    Veteran Member Three Rings TapouTx914's Avatar
    Apr 01 2008
    Yonkers, New York
    Only if im slowed down a lot going up a hill like my driveway to a stop or in very slow moving traffic. Other than that second gear can cover most since you can be going pretty slow in second gear
    Dec 30 2007
    Constantly changing.
    DC
    No......personally only downshift to 2nd.......and use 1st only from a complete stop.
    Active Member Two Rings Droogan Leader's Avatar
    Jun 09 2008
    Sunny SoCal
    Nope.
    The only time I shift into 1st is when I'm in stop and go traffic, and the revs line up sweetly. Other than that, can't say that I do.
    + The Droogan Leader
    2002 B6 1.8T
    Nov 09 2007
    Si,NY
    Quote Originally Posted by ThumperMK View Post
    Yea, cause u have a car with less torque then it takes to put on your lug nuts until 6k RPM. On my Audi, I use first to get moving. at 20 mph 1st is at like 4k+ RPM. I don't get the whole down shifting thing in cars. In my car I just roll. On my bikes I down shift becasue if I gotta boogie cause the ass behind me doesn't hit the brakes I got no cage 2 protect me, but then again I never get outta 3rd off the highway on the 600 and around town am usually in 1st or 2nd on the liter and 750. Hell on my I4 750 I don't leave 1st unless i'm on a large heavily trafficed road. I love an 85 mph 1st gear.
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    Unless im at a dead stop or going really slow (under 10) I goto 2nd, I dont use 1st unless I start off from it. Ive always downshifted to 2nd or taken off from it really. Habit from the truck i guess.
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Registered Member Two Rings
    Jun 12 2008
    900hp '99 Camaro SS / '04 A4Q
    So*Cal
    Nope...never do (with an exception)
    The exception is if I'm in bumper to bumper traffic and I have no choice but to shift to 1st.
    900hp '99 Camaro SS: - Slightly modded
    '04 B6 A4 Quattro - Stock for now
