Results 1 to 6 of 6
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    B7 OEM Nav question???
    So I am regretting not getting the nav in my new car, and now im thinking about buying one, but the dealer as many of you know likes to charge my left nut for it. I have been looking on ebay and all i can find are the RNS-E Nav plus. I believe the "E" stands for European. If i have the right nav disc will this work and if so will it fit in a B7?
    thanks.
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    Re: B7 OEM Nav question???
    E is the version of the navigation system the RNS-E is the newest out.
    edit: check out navparts.com
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    May 28 2008
    PDX/DEN
    your the man. thanks.
    Veteran Member Two Rings KMHPaladin's Avatar
    Dec 12 2004
    North Jersey
    navplus.us will tell you all you need to know. You can buy a retrofit kit on eBay if you're not inclined to anything more technical.
    Current: 2016 S3 Sepang Blue | 2006 Lotus Exige Storm Titanium
    Previous : 2006 A4 2.0tqm Quartz Gray | 1997 A4 2.8qm Europa Blue
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    You can find them on ebay but the european one wont work of the US. I think there are a few navi's for sale in the FS section on AZ.
    The usual things!!
    Resistor Install
    Nov 12 2007
    Grand Junction, CO
    The euro one will work in the US as long as it gets flashed with the US Firmware. Also check out www.navplus.us I have a euro unit and it works just fine. The only difference between the euro and the US unit is that mine says CD/TV instead of CD/SD. Once it gets flashed though, that button does the same on both.
