Results 1 to 20 of 20
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    Need help with intake tester for boost leaks.
    At a garage i used to work at we have compressed air with no control of how much psi comes out. I bought the intake pressure tester from VAST and what kind of regulator do i need to control how much pressure comes into the car? links where i can buy one? help!!!!
    i think i have a leak because my car is hesitating a little bit at low end performance and sometimes high acceleration
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Dec 06 2007
    Calgary, AB, Canada
    Re: Need help with intake tester for boost leaks.
    Just turn off the compressor when it gets to 15psi.
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    Or just go to sears and get a regulator for 20bucks
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Sep 27 2006
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Sep 27 2006
    so many people do this test and no one can answer my question? surprising
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    something like this?
    comes with a regulator and a seperate one indicating percent of leak, we use it when we check cyls when building the late model engines.
    or just buy a regulator?
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Dec 06 2007
    Calgary, AB, Canada
    I already did.
    And yes, that regulator will work fine if that's the route you want to take.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    That regulator looks good to me. My dad has a cheap air compressor that has a regulator so I just set it to 15-20 max, dont want too much pressure going into the car.
    I'm surprised the compressor you have doesnt have a regulator. But that one you had posted from sears should work good.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    is it possible that a compressor wouldnt be strong enough to pressure test?
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Jun 14 2007
    2000 S4
    Connecticut
    not really... I mean 15-20 PSI is usually the lowest a compressor will go. Some of them dont even go that low because if you buy a compressor for air tools you aint gettin that thing moving with under 90-100 PSI lol. like my uncle had a fairly big one, nothing crazy, but it was hard for us to get 15 PSI through it. we turned the dial ALL the way down and it was making about 12-13 on its lowest..... i had bought one from home depot that worked nicely until it broke 2 days later, i would of replaced it but i needed the 100. it was husky. perfect for pressure testing PERFECT
    Jun 14 2007
    2000 S4
    Connecticut
    unless youre using like those portable bike tire compressors those wouldnt hold the pressure probably for too long but not a normal sized one 10-20 is real low
    Jun 14 2007
    2000 S4
    Connecticut
    im being a post whore. this is the compressor i had it was perfect for p-testing.
    http://www.homedepot.com/webapp/wcs/...ctId=100536065
    Jan 21 2007
    01.5 Silver Avant
    dc
    that is the exact compressor i have....and dont know how to make it mate it up with the vast pressure tester...what do i need to get it done and secure the air?? how do i use it?
    Jan 21 2007
    01.5 Silver Avant
    dc
    come on guys...lol, i have a BL and need help finding it.
    Jun 14 2007
    2000 S4
    Connecticut
    OHHHHHHHHH you need to go to home depot man, and buy a connector thats all
    Jun 14 2007
    2000 S4
    Connecticut
    i know exactly what youre talking about, it looks like this
    go to home depot its a few bucks it screws on the end of your compressors hose then you pull back on it and attach it to the tester
    Jan 21 2007
    01.5 Silver Avant
    dc
    what size do i need? any idea??
    Jun 14 2007
    2000 S4
    Connecticut
    well if i were you id take the pressure tester over to home depot say i need to connect this to a compressor.... its a universal fitting. one of those gents will tell you.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by casawhites4 View Post
    It's a standard quick disconnect for air tools. I just pressure tested with my "mobile" tester a few minutes ago:
    Portable air tank filled with tire pump compressor.
    Quick disconnect at intake tester
    Capped off breather
    Bottle of soapy water sprayed on hoses
    Jun 14 2007
    2000 S4
    Connecticut
    exactly.. its a universal fitting. like when i used my uncles big shop compressor he actually already had it since it comes with some of the more expensive compressors. just go to homey depot they'll take your money and help for sure
