Results 1 to 16 of 16
Thread: Blown turbo?
    Nov 02 2006
    '01 S4, '89 Civic SI
    San Carlos
    Blown turbo?
    Is it possible for a blown turbo to leak oil on the outside? I have oil seeping on the hose under drivers side turbo, and cannot locate the source. hoping its a valve cover gasket...
    thanks in advance
    Nov 02 2006
    San Carlos
    Re: Blown turbo?
    There are a few drops of oil on the underside of the waste-gate actuator too...
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: Blown turbo?
    well is your car smoking like a military spec smoke bomb out of the tailpipes? are you not boosting at all? do your turbos sound like a thousand screaming babies being punched?
    you will know if your turbos are shot
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Nov 02 2006
    San Carlos
    Re: Blown turbo?
    Quote Originally Posted by jungb5s4 View Post
    LOL! no smoke out the tailpipe, no screaming babies, but there is a burning oil smell and i can see oil from underneeth the car. Oil line? really hard to see/find the source- any suggestions.
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Re: Blown turbo?
    My car spat smoke out the tailpipe... Like fog machine smoking bad... And the turbos sounded like a dentist drill. You have a mediocre oil leak. Wipe everything off that you think the area is from. Then drive it and look for where it's at.
    Jul 07 2007
    Tempe, AZ
    Re: Blown turbo?
    could it be an oil line not connected properly? or cracked/leaking? if it's not a 2001.5 (when they redesigned the oil lines), could it be possible that the older style broke? even possible if it is a 01.5 that they broke
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Re: Blown turbo?
    Quote Originally Posted by FCSTI View Post
    thanks in advance
    ya thats my guess, maybe cam seal leaking. Try taking a look behind the driver side head and figure out if you see any oil residue where the blck round cap is on the head. that area is right above the turboo
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Jul 07 2007
    Tempe, AZ
    Re: Blown turbo?
    rear main crank seal like mine leaked was retarded...
    Apr 13 2008
    Tennessee
    Re: Blown turbo?
    i'd vote for cam seal
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: Blown turbo?
    I had an audi mechanic tell me that audi's are notorious for leaking oil. I doubt it means the turbo's are bad like everyone is saying.
    Mine has a little of an oil burning smell right now too, not sure where its coming from so hopefully sometime this summer I can investigate.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Nov 02 2006
    San Carlos
    Re: Blown turbo?
    Thanks for all the feedback. I'll try to clean up the area, take off the coolant reservoir and see if can find anything "freshly" seeping...
    Dec 14 2006
    TX
    Re: Blown turbo?
    Quote Originally Posted by S4 in_lowplaces View Post
    I have oil leaking from the black round cap on the driver side. How do you remove the cap? Will a cap replacement be sufficient to stop the leak?
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    Re: Blown turbo?
    have u had your valve covers replaced at all?
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Re: Blown turbo?
    Quote Originally Posted by chonutz View Post
    Your oil cap is leaking?
    Dec 14 2006
    TX
    Re: Blown turbo?
    Quote Originally Posted by Evilevo View Post
    It's the head cap at the back of the motor.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Re: Blown turbo?
    Quote Originally Posted by Jung View Post
    Actually, it has never been proven that they redesigned the oil lines.
    Quote Originally Posted by S4Wiki.com
    Note: It is a common misconception that 2001.5 introduced updated oil lines. There is no conclusive evidence of this
