Results 1 to 25 of 25
    Senior Member Three Rings Stockton's Avatar
    Mar 04 2008
    2004 A4 Quattro 1.8t 6spd
    Palm Beach Co, FL
    Lubricating my sunroof track?
    What is a good lubricant.
    I don't want to use something to liquidy and runny.
    Anyone have any suggestions. In the maintance it says to inspect, clean and lubricate sunroof track.
    It's summer now and I'm using my sunroof pretty much daily so I figured it would be good to clean up and lube the track but I don't know what which lube would be good for it.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Lubricating my sunroof track?
    Clear lithium sythetic grease
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I have sprayed White lithium grease in there before and it definetly worked.
    But the proper way to do it would be to, probbaly, remove the headliner and remove all the built up grease from over the years
    -Sami-
    Veteran Member Two Rings
    Mar 16 2004
    NorCal
    white lyth seems to be metal to metal: http://www.valvoline.com/pages/produ...asp?product=37
    silicone might be better: http://www.valvoline.com/pages/produ...asp?product=36
    haven't tried it yet
    Veteran Member Three Rings ewytt's Avatar
    Sep 19 2006
    2016 SQ5, 2012 Turbo Beetle
    what is the process of doing this? It is apart of the 60K check up, right? Mine runs out of lubricant towards the end of it's path to being open. I think the dealer forgot to lube it during that check up.
    DIY out there?
    2016 SQ5 || 2002 Turbo Beetle
    Jan 17 2008
    ky jelly ;)
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    CO AVANT, do you think non-synthetic white lithium will be bad ? That's what I did, and I wouldn't want to ruin my sunroof. At least it's not creaking anymore now.
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    I believe White lithium sythetic grease is what the dealer uses but if I remember correctly its like $30 for a small tube
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STĂSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Veteran Member Four Rings JerseyShoreA4's Avatar
    Jun 17 2007
    2013 B8.5 allroad (current) 2007 b7 a4 (previous) 2006 vw touareg (previous) 2003 b6 a4 (previous)
    Ummm the Jersey Shore
    I think I used 3in1 oil/lube last time. it's kinda watery but it lasted all last summer. It's time for me to lube up again so I'm curious as well to see what works best.
    Miss my B6
    Feb 12 2004
    Everywhere
    Quote Originally Posted by gtimart View Post
    You will not have a problem. It actually helps prevent rust and corrosion.
    Dec 19 2007
    York, PA
    Quote Originally Posted by DeanUW View Post
    you can get white lithium grease at any auto store for like 4-5 bucks a tube
    Feb 22 2007
    Auburn, WA
    Quote Originally Posted by n7plus1 View Post
    Really? I went to a huge schmucks and they were like, "WTF is that?" so I laughed and gave up on my search figuring it was something only the stealership sold. I guess I'll keep looking, which store did you find it at by the way?
    Feb 12 2004
    Everywhere
    Feb 22 2007
    Auburn, WA
    Nice! Thanks Co Avant, never would have thought to look at Lowes
    Dec 25 2004
    Earth
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Senior Member Two Rings OldmanRacer's Avatar
    Jul 21 2013
    '87 Supra, Murano
    How do you lube it? I been wanting to do this to my sunroof but not sure how to go about doing so other than removing the headliner
    Established Member Two Rings HapIo_B6's Avatar
    Oct 07 2013
    PA
    Yeah, I'd like to figure this out. Mine just started squeaking reaaaly bad. It definitely needs it.
    2015 A3 Prestige | Mythos Black - Sport Pack
    2004 A4 1.8T Q 6spd - HP-2 Fronts w/SS lines - G.I.A.C Tuned - SOLD
    Feb 12 2008
    Michigan
    Can you just put it in the tracks and open and close the roof a few times or is it mechanical that need lube?
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Quote Originally Posted by Fast4esT View Post
    That's usually what I do. Easy to spot the "wear/rub" marks on the track. I wipe the old gritty gunk out before reapplying the grease. I also lube up all hinges I can access. If you use spray lube/grease be cautious of the sunroof being open. Easy for over spray to coat the interior. It's also a good time to check the drains for debris and proper function.
    Sent from my SCH-I645
    Daniel J
    @gtg_drives
    Senior Member Two Rings ecbo0m's Avatar
    Aug 07 2009
    05 S4 Avant
    Has anyone thought about using BMW sunroof lubricant? Smaller tube but much cheaper.
    https://www.ecstuning.com/b-genuine-...t/83192157321/
    Any differences between that and the OEM VW/Audi verison?
    https://www.ecstuning.com/b-genuine-...ase/g00045002/
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by MikTip View Post
    This. I wouldn't use anything else, may be fine, but why chance it.
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    I just called Rose City Sunroofs here in Portland, OR and the guy said they use "Super Lube" to grease/lube all sunroofs.
    http://www.homedepot.com/p/Super-Lub...1030/202932687
    I'm as cool as a cucumber in a bowl of hot sauce.
    Jan 02 2017
    Ontario, Canada
    Any synthetic (non-petroleum based) grease will do. Otherwise the polymers in the track will be attacked and soften. The PTFE grease above is a great product to use, it's Teflon-based.
    The Audi grease would be great to apply bodily before paying for it.
    Jan 01 2012
    2004 A4 Avant
    CO
    It's only 6 screws to remove the sunroof glass panel and it will give you plenty of space to clean the tracks and lube them
