Results 1 to 40 of 69
    Oct 29 2005
    10speed
    San Francisco, CA
    Well, the oil had to be going somewhere
    This could be a blessing in disguise... its possible that my rings are gapped fine and my HG was just slowly going to shit... I had been spinning my car to like 7k haha but whatever I was going to put some new rod bearings in there and maybe Ill get a few new sets of rings
    - Clint
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Re: Well, the oil had to be going somewhere
    looking at your other thread i was thinking to myself did he check his coolant?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by vdubstreets View Post
    I had seen a small bit but shrugged it off at first... Not sure if the the rings are gapped right or the HG has been bad the whole time...
    - Clint
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    At least you're not angry. I would have kicked my door in.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by ILoveT View Post
    lol realistically a headgasket is like $20
    - Clint
    Active Member Four Rings
    Dec 11 2006
    Boston
    "7 Grand!"
    Are we gonna pull your motor too?
    Stage 3+ RS6's
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    still sucks you got to go through the motions of getting it all right again after not too many miles on it. At least yours didn't grenade like mine did I'm sure you will get her all fixed in no time Clint.
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Clint! You CAN take close up pictures!
    My coolant reservoir looks like crap but it gets lower, not higher so with any luck it's just the flange (or oil cooler). We will have to flush it, too.
    2002 A4 FTW!
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Dec 11 2006
    Boston
    Quote Originally Posted by wolfdog View Post
    2002 A4 FTW!
    hahah yeah man, he has been honing his skills.
    Stage 3+ RS6's
    Oct 29 2005
    10speed
    San Francisco, CA
    2002 A4 FTW!
    is yours milky? if not its probably the oil cooler
    Derek I think the 7 grand pulls did me in!
    - Clint
    Nov 22 2006
    7 grand! lol. I'm a poser.
    2002 A4 TQMS
    Dec 11 2006
    Boston
    Find a way to blame it on Reilly.
    Stage 3+ RS6's
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I know VW used to have a problem with the oil coolers cracking and leaking coolant into the oil. I'd try that first, flush it and put just water to see if that will fix it.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by dirtybrd View Post
    lol been there done that I wrote the writeup for it Chris... I think we have a bigger problem on our hands. O well I needed better rod bearings anyway lol
    - Clint
    Dec 11 2006
    Boston
    You think that gave you the rod knock
    Stage 3+ RS6's
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    you got an oil pressure gauge on that bish clint? also, if the headgasket was leaking that bad youd notice tons of smoke lol
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by 317ssayzarc View Post
    no OP gauge, heres the catch... Its been eating Id say a quart every 500 miles or so maybe more maybe less. Car ran like a champ and whatever, but I would spin it to like 7200ish at least once a week. I have to do new rod bearings anyway so I guess this isnt so bad
    - Clint
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Just for future reference, how hard is the HG job on a 1.8?
    CEO and General Manager of the AZ Pedal Responce Team
    Oct 27 2007
    In the lab
    my motor has a faint knocking sound, it partially goes away when the car warms up so im thinking piston slap... i set my wall to skirt at .003 and thats pretty tight as far as aftermarket pistons are concerned... i rev it out to 7700 and oil pressures stayed at 30 at idle since the first startup, so i dont think its bearings... im start to give up on this car
    Dec 11 2006
    Boston
    Clint, when I was driving behind you one day in the red monster, I did notice a little bit of smoke coming from your exhaust...but I would hardly say you were burning oil.
    Stage 3+ RS6's
    Nov 22 2006
    Quote Originally Posted by deb38 View Post
    +1
    It definitely does that when he gets on the gas. It didn't happen much on the way to Doug's cookout, just when he got on it a bit. I think that also happened before he went 2.0, when I followed him to the DJD GTG last year.
    2002 A4 TQMS
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Puma297 View Post
    I'd say the easiest way is to disconnect the turbo inlet and downpipe. Disconnect the throttle body charge line. Then pull the valve cover off. Then set the engine to TDC on cylinder #1 (for TB realignment). Then unbolt the head bolts. Then remove the coolant lines and other misc stuff. Then pull the head off with both the intake and exhaust manifolds intact. Replace gasket and reattach everything.
    Clint.
    You're oil cooler is still holding strong? Even after you replaced it pre-2.0 build?
    The car ran fine when I drove it the other weekend. Dare I say I took it up near 7k in 2nd gear once or twice ??? That damn K03 kept making me ask "When? When? When will it kick in?" haha. I did like the long gears of that 2.8 trans and the suspension work you have done.
    PS. The AVant might come back to life sooner than I thought...
    -Doug
    Oct 29 2005
    10speed
    San Francisco, CA
    Clint.
    Doug, sounds good about the Avant. You noticed that the K03 doesnt die out like a normal one right? Its odd I dont know why that is the car doesnt really die out but whatever, I cant wait for some serious lag
    And also, Ill be taking some pics when I do the HG
    - Clint
    Oct 29 2005
    10speed
    San Francisco, CA
    Question... does revving to high cause blown HGs?
    - Clint
    Oct 27 2007
    In the lab
    no, super high cylinder pressure does (could be caused by many things) provided the mating surfaces were good and the head was torqued down
    Oct 29 2005
    10speed
    San Francisco, CA
    I heard heat does it also... that would explain everything cause I busted a coolant line and pegged my needle to the hot twice by mistake
    - Clint
    Oct 27 2007
    In the lab
    yup, that could warp the mating surfaces
    Feb 12 2004
    Everywhere
    Are you not keeping an eye on your coolant, egt, etc temps on vag?
    Take a flashlight and look down your sparkplug holes with the plugs taken out and tell me what the top of the pistons look like. or post pics.
    BTW, headgasket job is like taking out half the motor, minus the shitty bellhousing bolts thank god...
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    plus new stretch bolts. and valve cover gasket. and a decent amount of time all while making sure your timing doesn't get knocked off..
    but looks like you were already going to be in rome, so enjoy the stay i say
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jan 25 2006
    A4 2.0T
    MD
    For the record 7000 RPM is not high!
    Feb 17 2005
    Sarasota, FL
    Another built motor coming back apart ... big surprise!
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by A4ringedONE8T View Post
    lol I still give myself tons of credit
    Jordan, is it possible I toasted my pistons? What happened was like 3 days before school ended I blew this coolant hose (I called u that day) and I tightened her up but it never fixed it. So I kept putting in distilled water (it was a slow leak) just to get home because there was no one to help me at school. 1/2 way home it ran out again and I filled it. But thats the only thing that happened
    - Clint
    Feb 12 2004
    Everywhere
    possible but I think your problem lies elsewhere. Have any metal shavings come out of the oil when it was drained last? When your rear coolant hose went, did you drive around until the coolant light came on? Was there 0 coolant in the reserviour when you stopped to inspect it? If so you engine was HOT AS SHIT. This is not good and can warp the cylinders, blow a head gasket, etc, etc.
    Mar 21 2006
    Lakeland, FL.
    I still think you have a cooler issue. If the head was warped or the gasket was blown you would for sure have some drivability issues.
    I'm back bitches!
    Feb 12 2004
    Everywhere
    I feel he did his piston clearances too tight. I would go 4/1000's. For Clint's sake I hope it's as simple as a new oil cooler. That would be an easy fix compared to having to take off the head again. I would still like you to inspect down the spark plug holes though. I'd spend some time on it soon. Take off the cooler and inspect for mixing at that point. You might be able to reuse that gasket/flange if you don't damage it.
    Jan 25 2006
    A4 2.0T
    MD
    Did it over heat when you had the coolant issue?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Don Supreme View Post
    yes there was not much I could do... I was in traffic
    - Clint
    Mar 13 2006
    2002 A4 1.8TQM
    Columbus OH
    It is very likely you warped you head. Normally I'd say you'd have drivability issues and smoke... but there's exceptions to everything.
    Upgraded the motor a little, brakes a little more, and suspension a lot.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Mikef5000 View Post
    the car ran great... Would it warp my pistons and block also? or just the head? And what part of the head would it warp? could I just get it machined flat again?
    - Clint
    Oct 27 2007
    In the lab
    No to the pistons, very unlikely to the block and the head may be savable depending on how much its warped
