Results 1 to 21 of 21
Thread: PCV System
    Dec 17 2007
    MI
    PCV System
    I have oil in my system and wanted to change the Breather Ventialtion Tube Housing. Wanted to know what the correct term is. Thanks
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: PCV System
    More details?
    Engines are supposed to have oil in the system silly goose!
    ΜΟΛΩΝ ΛΑΒΕ
    Dec 17 2007
    MI
    Re: PCV System
    Well, to start I had a crack in my Breather Tube. I replaced it, along with the valve cover gasket, and Now I am seeing oil in my pancake valve, a check valve and alot in my PCV valve. It is actually cake-ed up in my t housing that connects my breather hose, pcv, and the line that runs to the air intake. I was figuring that either my housing is not holding oil, its too much oil in the crank case, but it was leaking before, so I do not know. I am just trying to cover all the \basis before I put it back together...
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: PCV System
    Normal. Now if you pull off your IC pipe and plenty of oil flows out of it you have a problem.
    Mar 04 2007
    nothing
    nowhere
    Re: PCV System
    Sooooo, what does that mean, especially if you are not loosing oil? Mine seeps, but then you take the hose off and about 1-2 TSp's come out...
    ΜΟΛΩΝ ΛΑΒΕ
    Senior Member Three Rings jlien08's Avatar
    Jun 28 2007
    98.5 A4 1.8TQT, 01 ZR2 Blazer
    Woodbury, MN
    Re: PCV System
    I've got small amounts of oil in my intake manifold. enough to make a drip when I removed the throttle body. I don't think that is normal, is it? I'm starting to think the seals on the turbo are gone.
    1998.5 Audi A4 1.8T Quattro Tiptronic - MagnaFlow - Bilstein - Neuspeed - EvoMS - 034MS - LLTek - FMIC - VDO -
    Dec 17 2007
    MI
    Re: PCV System
    IC pipe? I am sorry, we use alot of abreviations at the job, so IC does not immediately register with me..
    Mar 04 2007
    nothing
    nowhere
    Re: PCV System
    Quote Originally Posted by timjadams View Post
    IC = Icey
    J/K.... It is short for intercooler...
    ΜΟΛΩΝ ΛΑΒΕ
    Jul 07 2004
    socal
    Re: PCV System
    Quote Originally Posted by jlien08 View Post
    That is not normal and your SMIC/FMIC is going to have plenty more if it is coming from your crank breather or turbo.
    Quote Originally Posted by Ewok_Fetus View Post
    Just the way the system was designed since the oil in the vapor being sucked out of the crank case just builds up at the lowest point and then slowly moves its way toward the motor with the flow of air. If it gets to the SMIC or a FMIC if you have one then it ends up clogging up the core and decreasing how much air can flow thru it.
    This is exactly why people put catch can setups on their car since any oil that gets into the system decreases power.
    Registered Member One Ring llA4benll's Avatar
    Mar 24 2008
    1997 audi a4 1.8t
    clifton
    Re: PCV System
    turbo is shot
    Euro Performance
    77wabash ave
    clifton n.j 07013
    Established Member Two Rings EOD-5's Avatar
    Apr 20 2008
    98 A4 1.8tQ, 1990 Miata
    Newark, Delaware
    Re: PCV System
    Quote Originally Posted by llA4benll View Post
    turbo is shot
    not necessarily
    1998 Audi A4 1.8tQ 5 Speed
    VVME 4300k, RS4 Grille, GIAC, Piper Cams, APR TIP, Blinktek Heatshield, Forge FMIC, Catch Can, TurboXS BOV, PowerGasket, ECS FP Gauge, VDO Boost Gauge, ATE Slotted Rotors, PBR Pads, RubberTite Floor Mats, 034 Coil Cover
    1990 Mazda Miata
    not stock
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: PCV System
    I pulled my TB inlet hose off yesterday to replace the thermostat and the hose had oil on ints inner walls and was dripping a little. I cleaned that out and wiped the connection.
    Makes me think that the SMIC has lots of oil in it then and I've had a nifty power loss lately. I was thinking of pulling both hoses off the IC and spraying throttle body cleaned or even brake cleaner down the top of the IC and having it degrease it and flow from the bottom into a pan?
    Anything else I can spray there, I want to drown it in the stuff and then let it out at once.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jul 07 2004
    socal
    Re: PCV System
    Quote Originally Posted by nebone22 View Post
    Pull the SMIC out, plug one side, then fill it with cleaner or gas, plug the other end and shake it for a bit. This way you can clean all of it, just spraying it from the top with it still installed is only going to cause the stuff to run down just a few tubes inside core.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: PCV System
    It would seem that the oil resides mostly on the bottom of the SMIC and not so much in the tubes. People on vortex cleaned theirs and got almost 2 cups of oil out...thats crazy. They said it just flows out from the bottom like oil from oil pan during oil changes.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: PCV System
    well those people obviously had a bad pcv valve lol...
    Jul 07 2004
    socal
    Re: PCV System
    Well if it is in your TB hose it cant just be at the bottom of the SMIC can it?
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: PCV System
    Some gets through for sure so the channels will be oily. I'll just drain it for now and see what I'm dealing with. I don't think the AWM even has a PCV.
    Jul 07 2004
    socal
    Re: PCV System
    All 1.8t's do. The AWM has it for both the crank case and valve cover while the earlier cars had it on just the crank case.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: PCV System
    After I drain the IC I'll know if I need new PCVs.
    Dec 17 2007
    MI
    Re: PCV System
    I found my issue. I put my car back together and changed the pvc since I had it apart. I went to get an oil change and the guy told me that we take 3.7 to 4 quarts of oil......
    I remember every time before this that the oil places put at least 5 quarts in my car. My crankcase was overfilled. I have a new issue now. I do not have any boost after utting my car back together. I think I put everything back on correctly. Can any breakdown the schematic to direct me where the hoses connect on the connections under the intake manifold?????????????
    Jul 07 2004
    socal
    Re: PCV System
    If you have a dbw car one of those connections under the intake manifold goes to your BPV.
