Results 1 to 24 of 24
    Mar 21 2007
    03 A4 1.8TQM
    Los Angeles, CA
    Question used Seafoam... car stopped working! any ideas?
    So, last Thursday, I put a can of seafoam in my gas tank before a fill-up. Then, 30 miles into the tank my car is "putting," wont go over 5 mph, and my MIL is flashing. After speaking to Seafoam tech support, I changed out my fuel filter (it had been at least 40k miles... I know, bad A4 owner). The fuel that came out of the filter was BLACK. I got everything put back together with the new filter and fired her up. It seemed to be doing okay at idle, but when I got to driving it I couldn't give it more than 1/4 throttle w/o that same "putting"...
    So this morning, I pulled the new fuel filter and checked it for clogging. The fuel came out normal looking (with the exception of a clear oily residue, I assume thats the seafoam) and when I blew through it, it was only slightly more resistant than before I installed it.
    I'm about to pull my injectors to see whats going on in there... other than that all I can think is that I fouled up my fuel pump.
    Does anyone have experience with this or have any ideas???
    btw... I have a '03 A4tQM
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Re: used Seafoam... car stopped working! any ideas?
    I could be wrong but I don't think you are supposed to use and entire can.
    CEO and General Manager of the AZ Pedal Responce Team
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Using the entire can shouldn't hurt anything as long as it was put into a full tank, the detergent properties aren't powerful enough to really do any damage.
    Sounds like you may have blown a coilpack or two (or three...). If so, chances are it's just a coincidence.
    -Darrick
    Established Member Two Rings setay's Avatar
    Jan 03 2008
    Carson, CA
    ya, i believe its a third in the gas tank, a third in the crankcase, and then a third through the intake manifold?
    Cal State University Dominguez Hills
    Mar 21 2007
    03 A4 1.8TQM
    Los Angeles, CA
    Quote Originally Posted by Capt. Obvious View Post
    I had not thought of that... how can you tell which coilpack is blown?
    Nov 14 2006
    Gig Harbor, WA
    Without a VAG-COM, you'll need to just get a new coilpack and try replacing each one until the car runs correctly again.
    -Darrick
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by setay View Post
    2 cans total...
    1 in tank
    1/2 through oil
    1/2 through crankcase...
    ΜΟΛΩΝ ΛΑΒΕ
    Mar 21 2007
    03 A4 1.8TQM
    Los Angeles, CA
    Thanks Capt. Obvious! (no pun intended)
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    you can test your coil packs by simply pulling out one CP out while the car is running
    if the tone of the engine changes, that means that coilpack is working fine..
    but if u pull one out and you notice the engine still sounds the same, that means that coilpack is gone!
    Mar 21 2007
    03 A4 1.8TQM
    Los Angeles, CA
    Quote Originally Posted by GtiRSmiley View Post
    CP#2 = bad
    My first cp issue... I feel like I'm part of the club now.
    Thanks for all the help guys!
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Quote Originally Posted by Ewok_Fetus View Post
    2 cans total...
    1 in tank
    1/2 through oil
    +1
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I use one whole can in my gas tank. Never had a problem and I do it about every 10k to keep the injectors and fuel system clean.
    -Doug
    Oct 28 2007
    Ocean Beach, CA
    2 cans total...
    1 in tank
    1/2 through oil
    whats the difference in "through crankcase" and "through oil"?
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by Puma297 View Post
    NOTHING! LOL! My kid was distracing me while I wrote that.... She was throwing chicken nuggets everywhere... So I had to yell at her...
    But yeah, oil and intake manifold... Same thing!
    ΜΟΛΩΝ ΛΑΒΕ
    Nov 22 2006
    lol, I +1 and didn't even realize that! I read it and thought intake mani.
    2002 A4 TQMS
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Quote Originally Posted by csondaatje View Post
    CP#2 = bad
    Glad it worked for ya..
    Registered Member Three Rings
    Aug 06 2007
    02 Audi A4 1.8T Q Tip
    New Jersey, USA
    Hmmmm....... I think I'm a seafoam junkie.
    twice a month, I use 2 cans per fill up. YES YOU READ THAT RIGHT..... 2 cans per fill up, twice a month (i.e. 4 cans per month).
    then.... every 2 oil changes, i use 1 can in the crank case (oil).
    then.... every 3 months, i use 1 can in the intake vacuum (i.e. 1/2 can for 1st treatment on DAY 1.... 1/2 can for 2nd treatment on DAY 3).
    Mar 04 2007
    nothing
    nowhere
    That is seriously WAY too much... Every 10k miles is good... This comming from the person that made the write-up and pretty much introduced Seafoam into the Audi community...
    ΜΟΛΩΝ ΛΑΒΕ
    Aug 06 2007
    New Jersey, USA
    I know EWOK..... I've been over doing it with the Seafoam treatment.
    I'll get over it soon..... promise.
    And for those who read my post.... "DO NOT FOLLOW ME.... I HAVE A FORM OF SEAFOAM OCD".
    Senior Member Three Rings jettman's Avatar
    Feb 27 2006
    punta cana, dominican republic
    Quote Originally Posted by My OOOO My View Post
    Any one use something other than seafoam
    Kiss the rings bitch
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by jettman View Post
    Only thing I use: Auto-RX
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    interesting looking stuff. I checked out their site, and it said to use dino oil during the cleaning process. Do you do that?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Custom lubricant from a company that does industrial additives at nuclear plants. VOILA!
    Lubrication Engineers "L-X".
    L-E website
    L-X 2300
    Flyer
    MSDS
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    I use chevron gas. it has techron. BMW's magical injector cleaner says on the bottom "techron". lol. you don't need to put crap in your car to keep the injectors clean if you stick to a good formulated gas like chevron consistenly.
    104K miles and still going strong as day 1.
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
