Results 1 to 8 of 8
    Veteran Member Three Rings mwbunns4's Avatar
    Feb 20 2008
    2011 Audi S4 6MT, Audi A3 TDI
    Savannah, GA
    Bentley Manual worth it???
    im trying to do my downpipes and some other work on my car, but like a lot o us i need pics/diagrams to go by and detailed instructions. ive been looking at the bentley cd manuals. Is this really worth it? does the manual provide the pics i need????
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Bentley Manual worth it???
    If you plan on keeping the car for a while and working on it yourself I'd say it's definitely worth it.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Three Rings Paulyworld1432's Avatar
    Dec 07 2007
    Houston, TX
    Definite Yes
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    ^^ Agree. I own the online version.
    2015 B8 SQ5
    Click Here
    Past
    Feb 23 2008
    Atlanta, GA
    No. I own one and very rarely use it. The search feature on this forum + audiworld will better guide you, and provide usable pictures, for almost any project compared to the Bentley. The only thing I use my manual for is identifying gaskets to re-order when doing larger projects.
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    i say yes all the way
    Registered Member Two Rings lostinnd's Avatar
    May 14 2008
    Grand Forks, ND
    Where is the best place to pick up the Bentley manuals?
    Mar 26 2007
    2001 S4, 1999.5 A4
    Chambersburg
    Ebay--be sure to get the authentic version, however...
