Results 1 to 9 of 9
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    DRL Problem...Any ideas...?
    All things i can understand on my A4.
    However, there's one I cant.
    I've purschased it, with the extra, of DRL, Bi-Xenon, with adaptive light, and also, there is inside the car, the button that u can turn on-off the DRL...
    Can anyone tell me y the f*ck doesn't it work ever...?
    I've turned it on, I've checked the Vag-Com, it seems on...
    Then y, oh why, doesn't it work...?
    Any ideas, are most welcome
    TIA
    Audi A4 in an RS4 body
    Mike
    Veteran Member Four Rings Vito Roma's Avatar
    Oct 08 2007
    Syracuse, NY
    Re: DRL Problem...Any ideas...?
    turn it to the position where is says 1 you will see there is a 0 and 1 turn it to 1 turn your car lights to auto or off and it should work unless a wire is messed up
    '12 Bril. Black A4 2.0T/Quattro/Prem+/Sports package
    SLine body/Sline Door sills/3 spoke pref wheel w.Paddles/Sport seats/VMR 708 Matte Black(19x8.5) **For Sale**/Custom Black OEM caps/35% Tint/Needle Swipe/Fob/"Wink" & Amber Delete/More VagCom/RS4 Grille/ Hoen Endurance Fogs/ST Coilovers *Sold* /Debadged/V1 w. Concealed display *Sold*
    Jun 02 2008
    Greece
    Yeap I've done that already, it is in position one, and they dont seem to turn on at any time...To tell u the truth, they never have worked since we bought the car...
    Isnt that a bit wierd...?
    And if there is a problem in wiring, shouldnt it pop an error, fault code, something like that...? Honestly i cant find it and it is very annoying
    Mike
    Oct 08 2007
    Syracuse, NY
    hmm...unsure my check engine light never came on when i had a problem with my intake manifold (that was weird too) something wrong with the bulb maybe? Take it into Audi and have them run a check
    Registered Member One Ring ra.CE's Avatar
    May 11 2008
    A4 1.8T B7- 07 & Toyota Hilux
    Paimio.Finland
    Did you turned lights on when you tested your DRL? It is only working with lights switched off.
    •·.¸¸.·´´¯`··._.·♠ra.CE To The Audi Days♠`·.¸¸.·´´¯`··._.·•
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    You purchased the DRL option?
    If you did then I guess this wouldn't help you, but here in Canada we only have 1 knob and it's for the coming home feature. Turns on the fogs after you leave the car for about 1 min.
    Jun 02 2008
    Greece
    Quote Originally Posted by ra.CE View Post
    Nope...I've tested them all...
    Quote Originally Posted by WhiteABanT View Post
    Yeah i know what you mean, I have this feature too...
    But while my come/leave home works fine, and turns on and off from the button, the drl simply WONT work...
    Mike
    Jun 02 2008
    Greece
    Got a Vag-Com connected today and I found it...Some stupid must have turned it off from the vagcom, and I couldnt turn it on form the button inside the car no matter WHAT I did...
    So its ok now...
    Jan 01 2008
    Long Island NY
    i shut mine off they suck look ugly.
