In my quest to solve why my car is so friggin loud when idling I noticed something.
The spring loaded tensioner pulley for the drive belt seems to be moving quite a bit.
My question is:
Is the pulley supposed to be moving a lot? I always thought tensioner pulleys stay tight instead of bounce around.
Here is a picture I stole from the timing belt write up (thx yoogene) to illustrate which pulley I am referring to.
It is the part that yoogene has used his awesome paint skills to make the yellow wrench on :)
If you don't have your entire front end removed..I think its the only tensioner you can see if you look straight down at the belts.
