Results 1 to 11 of 11
Thread: smoke? aw shit
    Senior Member Three Rings therox182's Avatar
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    smoke? aw shit
    When i drove to work this morning (3 minutes from my house), I got out of my car and noticed a slight bit of smoke and smelt a burning smell. I popped the hood and it looked like the smoke was coming from somewhere directly below the coolant tank. It wasn't coolant that was burning because I know what that smells like. I have no clue what it could be, so i'm hoping someone may be able to throw some possibilities at me. I know this may not be enough information, but its the best i can do on my lunch break.
    oh and if there's anyone in the northern jersey area that has a pressure test and would be willing to lend me a hand to see if i have a boost leak somewhere, thatd be sweet. thanks in advance
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    Re: smoke? aw shit
    valve cover? turbo? Sounds like oil leakage
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: smoke? aw shit
    probably valve cover. is the half moon seal on the front of the head on the driver side head? i think it is. i say this because my half moon seal on the passenger head is leaking onto my exh manifold .. something to always check.
    Veteran Member Four Rings ny02s4's Avatar
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    Re: smoke? aw shit
    valve cover or cam adjuster seals.
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: smoke? aw shit
    i dont see any leakage of any sort if that helps at all. theres no dripping from the bottom or any visible moisture around the engine bay. guh please dont be a turbo situation.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: smoke? aw shit
    if it's a valve cover, how difficult of a repair is it? how much $$$ am i looking at?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: smoke? aw shit
    Quote Originally Posted by therox182 View Post
    dude DIY. its NOT hard. http://www.audiworld.com/tech/eng52.shtml
    and the valve cover gasket set is like 25 bucks
    Apr 10 2008
    Re: smoke? aw shit
    maybe secondary water pump when it goes bad it usually leaks behind there and drips on the tranny. i can do a boost leak test for you but im located in staten island ny 10314.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Re: smoke? aw shit
    ^^^ i really dont think it woudl be that.
    Its your valve cover, just replace everything thats right there. Half moon, Tensioner gasket (cam adjuster), valvecovers and it shoudl go away.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: smoke? aw shit
    alright im gunna start looking into all of that. How serious is it if I were to drive the car as it is?
    Feb 09 2006
    Huntington Beach
    Re: smoke? aw shit
    Its not like having a blown tire which you need to fix right away but you shoudl get it done soon. GL
