Results 1 to 3 of 3
    Established Member Two Rings FatAuto's Avatar
    Feb 06 2007
    Greenwich, CT
    Losing boost while driving
    today on my way to work i was in 6th gear about 3k rpm i floored it to get ahead of a car when all of a sudden i feel a stall and my boost drops off. The gas pedal is still floored but I will not go any fast and my RPMs wont move.
    this has never happened to me before, i tried to replicate it and i was able to get the boost go cut off a few times but not every time.
    I have a k04 with revo software and all the supporting mods.
    It almost seems like my wastegate is opening
    Senior Member Two Rings fbottone's Avatar
    Sep 27 2006
    Stratford, CT
    Re: Losing boost while driving
    Sounds like spark blowout, from plugs maybe or a bad coil pack. About 2 days prior to a coil pack failure, I usually get similar behavior (stock programming works fine). Once it gets bad enough, you'll probably see the flashing CEL and then you can identify which one went.
    [ :: 2007 2.0TQ6MT :: Stock!!!! :: 44000 ]
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    I had that happen... It was my coil packs
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
