    Oct 03 2006
    B6 A4 TQM GTRS
    Singapore
    Stoptech Rotor Replacements 355X32mm
    Tried searching online but couldn't find the pricing of these.
    355X32mm Slotted
    355X32mm Slotted + Zinc Coated
    Any websites that sells these? or only through the agents? If so how much am i looking at for the replacements. Also what other stuffs should i do other than Rotors and Brake pads and brake fluids. Should i do a complete caliper overhaul?
    Thanks in advance
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Re: Stoptech Rotor Replacements 355X32mm
    you probably have to call em up.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Rotors are ~$200/each but you need pins as well and Stoptech will not sell them without the pins, so the price per rotor/pin set is ~250, and I think its $280 with the zinc plating.
    Caliper seals can be done if you have significant miles/trackdays, seal kits are $50/side, I reused the pistons. IMO dont touch them unless you need to or have significant mileage/heavy use.
    If you live in a really salty climate (winter road salt, or near the ocean) then get the zinc rotors. The non-plated develop rust in the floating pin "slots" and the rotors cannot properly expand, which causes the hats to crack. There is also the problem of galvanic corrosion, which weakens the aluminum hat grain structure and leads to premature failure. I went through two complete sets of rotors/hats/pins b/c of this problem, but it was before the zinc was an option.
    If I were you, first pull off the old rotors/hats and inspect the hats and the area around the pins. Im my case, it was impossible to separate the hats from the rotors b/c of corrosion. If you need a complete rotors/pins/hats setup it will run you around ~$1,000. Contact Zeckhausen racing for the parts, they may even cut you a deal. I think they are Stoptech's master distributor.
    EDIT: The above prices are for the 332mm rotors, add a little for the 355mm versions.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Quote Originally Posted by lookaught View Post
    ..... Contact Zeckhausen racing for the parts,
    Second them. They will answer even what may be the most stupider questions, too. Really awesome and they know their stuff.
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Third on Zeckhausen, Dave sells all Stoptech parts. He didn;t have what I wanted in stock but great customer service.
