Results 1 to 9 of 9
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    AWE Exhaust Troubles
    I've been running the AWE cat-back for about a month with ~1500 miles in that time, and ever since it was installed I've heard a clunking noise whenever the exhaust is warm and I go over bumps or poor road surfaces. I recognize that there should be an expectation of gurgling while it's being broken in, which I've heard, but what I'm hearing is definitely different.
    Even tonight in 3rd gear around 40mph, the sound seemed to be modulating and over every single bump it felt like the exhaust was rocking and making the 'clunk clunk' sound. The first time I drove the car with the exhaust on was also the first time I drove the car with PSS9's installed. Any chance this could come in to play? Yet, the change in exhaust note leads me to believe that the problem is strictly exhaust.
    Thoughts? Suggestions?
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    In Limbo Three Rings
    Jan 18 2008
    2006 A4 2.0T quattro mt
    central jersey
    Re: AWE Exhaust Troubles
    i have the same exhaust and when the car is cold you car here a loud clunk sound and when i give it gas when its warm you can still hear it
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Check all your hangers! maybe they didn't get the exhaust back into all the hangers and its hanging a bit low. check all the bolts and tighten them.
    Veteran Member Two Rings KMHPaladin's Avatar
    Dec 12 2004
    North Jersey
    Sounds like it's potentially clunking on the front subframe. I don't know if you had it installed or did it yourself, but it's important that you space the exhaust in the middle of the hoop in the subframe for the exhaust to go through.
    Current: 2016 S3 Sepang Blue | 2006 Lotus Exige Storm Titanium
    Previous : 2006 A4 2.0tqm Quartz Gray | 1997 A4 2.8qm Europa Blue
    Senior Member Three Rings groggy's Avatar
    Oct 20 2004
    Quote Originally Posted by agkellyboy View Post
    Did AWE install the exhaust?
    Veteran Member Four Rings SilverB7FL's Avatar
    Feb 19 2007
    Built Twin Turbo 350Z
    S. Orlando
    mine never makes any clunking noises I've had it on for awhile now too
    Girls love Audi too.
    Jan 18 2008
    central jersey
    Mine sounds like it is coming from the front and i had it installed
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    Quote Originally Posted by groggy View Post
    AWE did not, but I would trust that my tuner knew what he was doing. I'm close enough to AWE to take it there myself, think it's worth it?
    May 24 2008
    PA
    my exhaust slides back and fourth in the hangers hitting the valance.
