Results 1 to 25 of 25
Thread: Dts???
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Dts???
    does anyone have a drive train stabilizer? what kind of benefits do you get and would it be worth it. I think ECS makes one?? possibly? looking for some info
    Veteran Member Three Rings Vuel Egham's Avatar
    Jul 06 2007
    2017 Audi Q7, 2021 Tacoma Off-road
    Pleasant Grove, Utah
    Re: Dts???
    I have the AWE DTS. It keeps a modified S4s motor in place rather than ripping itself to pieces. Downsides: if you are too low, you will drag that shiz on everything.
    CURRENT
    2017 Audi Q7 | Carrera White | Premium + | Vision | Cold / Warm Weather | Bose | 20" | Towing
    2019 Audi RS5 Sportback | Glacier White | Black Optics | Dynamic | Steering | B&O
    PREVIOUS
    2018 Audi S4 | 2018 Audi RS3 | 2018 Audi S5 Sportback | 2015 Audi S4 | 2015 BMW M3 | 2011 VQ Tiguan / 2011 S4
    May 31 2008
    New York
    Re: Dts???
    whats mods done to your car?
    Jul 06 2007
    Re: Dts???
    Bilstein shocks, H&R race springs, Neuspeed rear sway, GIAC software, AWE cat back, Samco hoses, etc. It is pretty low, and bottoms out on a lot of things, got stuck in a car wash once.
    CURRENT
    PREVIOUS
    Apr 05 2007
    Re: Dts???
    Quote Originally Posted by Vuel Egham View Post
    yeah i've seen that happen way too many times..
    Veteran Member Three Rings saucys4's Avatar
    May 30 2007
    San Diego/SF Bay Area
    Re: Dts???
    save your money and get a solid engine snub mount from vast for 24 dollars. it does the exact same thing.
    J Fonz Stage II+
    Veteran Member Four Rings lnferno's Avatar
    Oct 14 2006
    Rocky Mountains
    Re: Dts???
    Like Vuel said - it harnesses the power better. It does exactly just that -- it stabilizes the drivetrain movement. The shifts feel more solid and the car overall just feels more solid. Very well worth it IMO.
    Current: 2021 Audi SQ7
    Past: 2014 Audi RS7 Stage 2 (quickest in Colorado) | 2014 Audi S6 Stage 1 | 2011 Audi A6 Suzuka Grey Avant (1 of 1) Stage 2 | 2006 Porsche Cayenne Turbo S | 2001 Audi S4 - Stage 3+ | 2006 VW Toureg V8 | 2006 A4 Avant - Stage 1 | 2006 Audi A4 - K04 | 2001 Audi S4 - Stage 2
    Veteran Member Four Rings Rapter's Avatar
    May 01 2004
    2009 honda CRV
    Jersey
    Re: Dts???
    Quote Originally Posted by lnferno View Post
    I concur I couldn't believe how much more solid it felt after I had it put on.
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: Dts???
    I can't go through most car washes with rails because its low, and when it scrapes the bottom, it hurts to witness!
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: Dts???
    Quote Originally Posted by saucys4 View Post
    Not quite. DTS bolts to the tranny. Snub mount bolts to the very front of the engine, just behind the bumper. Those are two completely different anchor points and will control drivetrain movement in different ways.
    Truthfully, if you really want to control drivetrain movement, get the DTS, order DTS upgrade kit from JHM, 034 snub mount and some new 034 motor mounts.
    That will lock your shizzle down. You won't believe the difference.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Veteran Member Four Rings ny02s4's Avatar
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    Re: Dts???
    i got stuck on the Bridgeport Ferry two times because my DTS was too low to the ground pulling onto the boat. Lil embarassing to say the least when you have 100 cars behind you lined up to board, haha
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    Re: Dts???
    ^^ lol^^
    I hit mine if I take speed bumps a little too fast, and when i get under the car, mines all scraped to hell...lol
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    May 30 2007
    Re: Dts???
    Quote Originally Posted by 2ndEngineS4 View Post
    What I am saying is that they both remove drivetrain slop, they have the exact same purpose and you wont be able to tell the difference of one over the other. The snub mount is just $24 and i cant see myself spending triple digits for a bar of steel that will probably not work as well. My DT slop was horrible and I installed a snub and it was night and day. Now I have no reason to get a DTS, I'm happy the way it is. Here is an interesting post that I think all of you should read that compares both a snub vs. a DTS. Its in the middle of the S4 articles and is labeled Improved Driveline Control. http://www.audiworld.com/tech/eng.html
    J Fonz Stage II+
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: Dts???
    ^^ Yeah, I read that article. It had some very good points and I used it for my decisions on driveline control mods. IMO, if the DTS is out of the question for you, 034 street density tranny and motor mounts coupled with the snub mount would be the best bang for the buck. That's going to firm everything up without bringing too much vibration from the drivetrain into the cabin.
    May 31 2008
    New York
    Re: Dts???
    Thanks for everyone's input. How hard is it to install a snub mount? And which brand should i go with?
    Oct 14 2006
    Rocky Mountains
    Re: Dts???
    I think it all depends on your mods. For a Stage I or Stage II, a snub mount may be sufficient, but for anything above stage 2, I would recommend adding motor mounts as well as the AWE DTS. The more torque your car has, the more it will benefit from keeping it stabilized. In a perfect world, having a snub mount, DTS, and motormounts will be the best way to keep your drivetrain stabilized.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Dts???
    doesnt the DTS help a ton with lateral (body) sway? not just motor movement?
    Dec 06 2007
    Calgary, AB, Canada
    Re: Dts???
    Yeah it does help, how much I don't know, but it does help.
    If you plan on launching the car hard, then get the snub AND the DTS. I can get you the poly DTS mount, the DTS, VAST snub mount, and the VAST RS4 motor and tranny mounts (or the 034 versions) if you would like.
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: Dts???
    Quote Originally Posted by The_Jerbel View Post
    What he said. I have all (DTS with poly mount upgrade, 034 motor and tranny mounts, and 034 snub mount) and I could not be happier. The drivetrain is ROCK solid. I have to admit that it does bring a little extra vibration into the cabin, but it is definitely worth the trade off over the stock mounts and it's not too noticeable.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: Dts???
    you ever get your fueling for stg3 yet? i gota check out your beast one of these days.
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Re: Dts???
    I had a stern snub mount by itself and felt the difference.
    Got a DTS from a member here and man, you definitely feel it also.
    I think the DTS would make a larger difference than the snub mount alone.
    Jul 06 2007
    Re: Dts???
    Quote Originally Posted by exorcet View Post
    It's called hyperbole my friend...
    It is effective, but like I mentioned if you are low, you will scrape things all to hell. Even after getting stuck a few times, the car still runs just fine. Just unseen cosmetic damage. :)
    CURRENT
    PREVIOUS
    Established Member Two Rings rick_chicago's Avatar
    Apr 29 2008
    B5 S4 (Stg 2), Honda CR-V
    Chicago (NW)
    Re: Dts???
    ...Just unseen cosmetic damage. :)
    Kinda like my wife after pushing out a couple of kids. I say that because she's the one who says "This thing's kinda noisy for a luxury car." All I have is the DTS.
    I just floor it and she shuts up and smiles.
    Stg 2 B5 S4
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: Dts???
    Quote Originally Posted by infinkc View Post
    yessir.
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Re: Dts???
    Glad to hear the goods news since I bought the AWE one a week ago, still need to put it in though
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
