My car has been burning oil (like 2.5 quarts every 3,000 miles). I can see a light oil cloud in the side view mirrors when I go wide open, so I decided to do a compression check.
I had 175, 160, 165, 160 for compression numbers. I put a cap of oil into the cylinder #2 with 160 (the oil will help seal worn rings for the test) and checked compression again. Well I had 185 then, so it went up 25psi. Looks like my oil ring is letting oil go by as well as the other rings being worn
Kinda sucks but I guess I will be tearing her apart sometime in the near future to replace the rings and while I am at it put in some stronger rods for maybe down the road.
