Results 1 to 40 of 42
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    This car's brakes suck!
    So I was driving my favorite mountain road today, and after about 10-15 minutes of spirited driving my brakes are faded to the point of having to slow down and drive like a normal person. I know the S4 is no lightweight, but I can't imagine these brakes lasting more than 3-4 laps at the track.
    Is this normal? Or did the guy I bought it off of put on a cheap set of pads? It makes me think track time is not worth it until I have a bbk. Those with track experience please shed some light on this.
    Also my oil temps were between 250-275. Seemed fine to me. Just want to make sure that is normal and it seems like a an oil cooler may be necessary for the track as well.
    And damn I need a rear anti-roll bar. This thing understeers with a capital U.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Senior Member Two Rings momento1's Avatar
    Feb 04 2008
    AUDI 2002 S4
    Sydney, Australia
    Re: This car's brakes suck!
    yeah the stock pads, calipers are prone to fade.
    They are good for the one or two in a row hard brake for emergencys but not continual hard track braking, the car is simply too heavy for the small brakes. Upgrading your pads and your brake fluid will help reduce fade slightly for continual hard braking, but to reduce this even further, largers rotors, calipers and better pads and fluid would be the ideal thing to do.
    Hence why i upgraded to the ECS porsche 6 piston brake kit. it has made a world of difference in continual hard braking.
    Currently i have the stock compound pads that came with the kit, but i will upgrade them when the time comes.
    well worth the upgrade IMHO
    CURRENT - Audi 2002 S4 Nogaro Blue Pearl - Stage 3+ 335Hp atw (but something isnt right...)
    PREVIOUS - Audi 2001 S3 Silver - 230Hp atw
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    StopTech 332 : )
    Feb 08 2008
    01' 2.9L GT S4 racecar built for TA/GTS competition
    North Jersey
    Brembos!
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Quote Originally Posted by S-Power View Post
    StopTech 332 : )
    2nd this, main reason i coughed up the 2k for the BBK cuz I have heard *numerous* stories about people toasting their rotors and pads after one day of track use......go big or go home. If you want to know where the cheapest place to get the Stoptech 332 kit, hit me up, i got it for $300 less than any tuner like avalon, achtuning, ect. sells it for....
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Established Member Two Rings rick_chicago's Avatar
    Apr 29 2008
    B5 S4 (Stg 2), Honda CR-V
    Chicago (NW)
    Everyone's right - you'll want to consider a minimum of rotors, pad and fluids if you're going to track it, BBK if you're going to track it often.
    But I might also suggest you take a look at your setup. The stock brakes last more than 3-4 laps at a track day. I've driven the mountain roads around Los Gatos. You shouldn't be getting that much fade after just 10-15 minutes.
    Stg 2 B5 S4
    Jul 06 2007
    San Jose, CA
    Quote Originally Posted by rick_chicago View Post
    The rotors are a little warped. They were like that when I got the car, but the pads were pretty new. It look likes the previous owner just did a cheap brake job before selling it. It does have new dot 4 fluid though.
    As for the road, I was on Hicks road if you know it. It has some nice elevation changes and on a stretch of down hill is when the brakes cried uncle. On the way back I saw a Taurus on it's roof on a section of road I was on 10 minutes prior. It was some guys in their late teens, early twenties. They were fine. They just got a lesson in why driving a Taurus at speed is not a good idea.
    Either way looks like I am going to need new brakes before I spend money on a track day. Which also means new wheels to fit the brakes. So it looks like it's going to be a while before I hit the track.
    Apr 29 2008
    Chicago (NW)
    You'll find my evil twin on the roads - a silver B5 S4 with Oettinger wheels and a stoptech kit. Or he'll be in a 08 Cayman or his wife in a Volvo V70R wagon. Good luck keeping up with them if you do see them! ;) I share his car at track days out there, and can return the favor when he's here now.
    I'm running Powerslot rotors and Hawk HPS pads. It's no BBK, but it's fine for the street.
    Stg 2 B5 S4
    Oct 31 2007
    Grand Rapids, MI
    if you do upgrade your brakes, there is no need for new wheels, as stoptech makes there 332 kit specifically to fit our stock Avus wheels
    MKIV BPM R32 (DD)
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    alcons ftw. otherwise b6 s4 setup is a good alternative
    Veteran Member Three Rings audiwop's Avatar
    Dec 11 2006
    2007 Audi RS4, 2010 Ford SVT Raptor, Toyota Tundra, VW Treg,Ducati Hypermotard 1100S
    Orange County,CA
    After 2 track days I said to hell with getting more speed out of this thing, Stage 3 ain't shit on a track if you cant go deep into a corner. Brembo 355's FTW, SS lines, race fluid and hawk hp-plus pads.
    Dec 11 2006
    Orange County,CA
    Quote Originally Posted by RolledMySTi View Post
    I do a lot of track days and will tell you this, rear sway is a must as well as a good C/O setup. But your biggest benefit will be track tires and brakes. I run Nitto NT-01's. I was stage 2+ my 1st track day with all stock brakes & suspension. After my C/O's, sway bars, brakes and tires I drop over 6 seconds. If you plan on doing track days do all this first and you will be on your way to a good setup.
    Veteran Member Four Rings skunkoncrunk's Avatar
    Apr 18 2007
    2006 Subaru WRX
    Cali/Colorado
    If you do buy new pads, take it from me that the Hawk HP Plus pads are prone to squeaking on everyday driving. They are great for spirited driving though. Audiwop might say different but he's also running Brembos.
    I think later down the road I will invest in a BBK. Braking is serious business.
    -Hooked on Meth-
    BOOSTADCT
    -Mike-
    Instagram: @mdundurs
    S4's Video (Watch in 1080p)
    Senior Member Two Rings nvrfollow's Avatar
    Apr 19 2007
    Silver S4 - Laser S4
    Montana
    Yeah stock breaks are not the best, i'm running ceramic pads and slotted rotors and a couple nights ago a buddy with modded sti and i went for a 2 a.m dirt rally to paved hill climb in light rain, when we reached the summit my oil temps hit 275+(not suprising) on the way down i hit the breaks after a short strait away and the break pedal just buttered all the way to the floor and didn't really do anything, when i managed to pull over both front rotors were billowing off smoke and the rotors were glowing bright!
    The sti driver said i had been smoking for some time... that has to be the hottest my car has ever been as my exhaust tips melted the bumper :(
    temps were at about 50 and the sti's stock brembo's with race pads were fine
    Jul 06 2007
    San Jose, CA
    Quote Originally Posted by nvrfollow View Post
    I believe that. I took my STi to the track the brakes never faded. I miss those brembo's.
    Mar 19 2008
    Tulsa, OK
    I like the initial bite our brakes have but the performance is just so-so. Get some ECS cayenne brakes.....pretty damn cheap.
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    A set of nice pads and SS lines will do a pretty good job. (and rotors if needed)
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    The stock brakes are actually really good for stock. Besides the cars have have brembos and such. I'd suggest adding SS lines, good fluid, better rotor/pads and see how that works out. Alot less money then doing a BBK...
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Jun 14 2007
    2000 S4
    Connecticut
    everyone refers to brake fluid as "some good fluid" what would everyone say is the "good fluid" =]
    Nov 10 2004
    Longview, WA
    I use ATE's super blue DOT 5 fluid.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Dec 11 2006
    Orange County,CA
    My hp-plus dont squel that bad at all. I did put the anti squel stuff on when I broke in the pads but don't have much of an issue with sqeeks at all. I ran the pads that came with the brembo's for a little bit but they fell apart after my first track day on them. Hawk is a good way to go. ATE super blue is what I run for fluid, it has a very high boiling point.
    Veteran Member Three Rings AUDILUX's Avatar
    Oct 16 2007
    B5 S4 / 335i
    There was a great article about a B5 S4 shootout in European Car in 2004, which included testing each S4s stopping distance (3 hard stops from a high rate of speed) as well as lap time around a closed circuit. The car that won for shortest stopping distance had Stoptech 332s up front and S8 rear brakes. Cars w/ stock brakes did ok on the hard stops but sucked it up big time on the track. I'll see if I can scan and post that article at some point in the near future.
    Established Member Two Rings Doc_S4's Avatar
    Nov 03 2006
    Buffalo, NY
    ATE Super Blue
    Motul RBF600
    Castrol makes a really good brake fluid too, don't recall exactly what it's called. It's rather expen$ive though ($75/qt.)
    Jan 11 2007
    Salt Lake City, Utah
    NO superblue
    Jun 14 2007
    2000 S4
    Connecticut
    see people told me when i went to go buy it that i couldnt use DOT 5 unless i was tracking... ? I ended up with like DOT 3 or 4
    Nov 10 2004
    Longview, WA
    Quote Originally Posted by jibberjive View Post
    NO superblue
    Care to explain why? I've used ATE superblue for years, in my DD and track cars with no problems at all.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Jan 11 2007
    Quote Originally Posted by Kruat View Post
    Yeah. I've actually got it in my car right now and am trying to get some RBF600 to replace it asap. It made my clutch pedal have a small squeak every time I push it in right after I flushed it. So I did a little research and apparently it's not good on the rubber seal on our car's master cylinder or something. I wasn't the only one who'd had the problem.
    Dec 14 2006
    Halifax, NS, Canada
    U dont want to use DOT 5 its silicon based and for motorcycles will mess up your system... DOT 5.1 is what you want for racing. Dont get confused. You also shouldnt use DOT 3, car came stock with DOT 4 for ABS.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    Quote Originally Posted by audiwop View Post
    What is this "anti squeal stuff" you speak of???
    Dec 11 2006
    Orange County,CA
    Quote Originally Posted by dennisS4 View Post
    I cant think of the name but I will find out for you when I get home from work.
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    Im running superblue fluid and i never had a problem with it..
    Dec 11 2006
    Orange County,CA
    Alright I remembered the name, its a product from BG.
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    I recently put some ECS stage 4's up front w/ some ATE superblue and the brakes feel great, the only downside I see with them is that stock wheels no longer fit and wheel selection is more limited. I'm sure just good fluid, more aggressive pads and some slotted rotors would be sufficient for most people anyways as long as the car isn't tracked much.
    Veteran Member Three Rings OneSickSedan's Avatar
    Feb 23 2005
    2001.5 Audi S4 6-Speed WMS Stage 3-
    Southern California
    Quote Originally Posted by AUDILUX View Post
    This magazine with the S4 shootout is always in my backpack. It's a good reference for a lot of things, not just braking. It's good to see what was good back then and what is good now. Good call though.
    2001.5 6-Speed Santorin Blue S4 (WMS Stage 3-,mod list in my profile)
    "Who, after all, speaks today of the annihilation of the Armenians?" - Adolph Htiler
    Let's end the cycle of genocide by recognizing the Armenian Genocide and end the Darfur Genocide.
    "If you're not first, you're last." -Ricky Bobby from Taladega Nights
    "LIVESTRONG" - Lance Armstrong
    Jun 14 2005
    Central US
    MOTUL RB600 high temp fluid
    Carbotech XP 8 or 10 Pads
    Oil Cooler
    Have Fun.
    Jul 06 2007
    San Jose, CA
    Quote Originally Posted by rharris View Post
    Oil Cooler
    Have Fun.
    Yeah. This thing is going to need new rotors, pads and a monster oil cooler before it can see the track.
    Jan 11 2007
    Call me crazy, my stock S4 brakes are TONS better than my 04' A4's brakes. And the stock rotors with race pads have been really decent for me at the track for 3 full days. Oil temps didn't get up either. These were 20 min sessions.
    Jan 11 2007
    Race fluid too
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    I have to agree with this car having some of the worst stock brakes I have ever driven on....especially for a "performance" sedan....they fade in like 3.2 seconds, i'd be terrified to bring this car on a track with the power levels i'm running...
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Senior Member Two Rings Fast Euro's Avatar
    Mar 23 2007
    2005 SLK55 AMG
    Buffalo Grove, IL
    Anyone have weird brake behavior in wet conditions? Thats where I am most annoyed with the stock brakes.
