Results 1 to 31 of 31
    Feb 27 2005
    North Wales, PA
    Pics....A little bit of everything...
    Matt (tamadrumr88) detailed my car today. Turned out great! Contact him if you need a detail. The front bumper is getting replaced/repaired so it was not touched...hence the reason it looks like ass.
    CF Hood shot for Fred
    My stripped down sedan. Let me know if you need anything!
    Engine build getting underway. Stage 1 - gather parts
    Powercoated pulleys and tensioners
    They good stuff...je pistons, scat rods, etc.
    AEB head on the way. Still need to buy high rate valve springs and ti retainers, new valves, and gasket set.
    I think i'm gonna go with a gt3076r with a .82 ar....or if its too laggy then I'll just throw on a .63 hotside on it my friend has laying around.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: Pics....A little bit of everything...
    Quote Originally Posted by Poopie View Post
    the 30r .82 could work well, but might i suggest a 35r .63? which displacement are you going with? let me know if you need anything
    Awaiting Confirmation Two Rings
    Aug 22 2007
    2000 A4 1.8T
    Bristow, VA
    The Avant looks even better in person, well put together.
    Aug 09 2007
    Mount Airy, MD
    dang man, im jealous. i want an avant.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by 317ssayzarc View Post
    I'm sticking 1.8L. So i was thinking 30r with a larger hot side for more hp....if it doesn't work out I can put my friends .63 ar hotside on. With the 35r I know its gonna be laggy...and then there isn't anything I can do about it.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    What about my skills with the PC and Menzera? Sheesh you've seen my details:) You missed Jens GLI from H20 which was TOP Dawg material, but left and went back to Ohio early;) looks great Aeron! Class is almost over so I can lend a hand after the 14th with everything.
    Oct 27 2007
    In the lab
    i see how you are thinking, with 1781cc's you are somewhat limited with turbo choice on a street car... the 30r .82 could have some decent potential with a gas higher than pump, but otherwise the .63 will provide all the boost you need and then some for a regular pump setup... i figured you were going beyond pump when you mentioned the .82 30r
    Oct 27 2007
    In the lab
    Quote Originally Posted by bassed View Post
    you did mike and jens detail? that was very nice
    sorry to threadjack but i used some menzera recently and found it a sweetheart to work with, but a bitch to remove... do you find this as well or did i not break it down enough? (it was my first time using it so i wasnt as aggressive as usual)
    Feb 27 2005
    North Wales, PA
    it will be running meth injection so we'll see what happens. The pistons are 9.25:1 cr so i can run some more timing and boost then I would have with the stock pistons.
    I also have awm Integrated engineering rods for sale...brand new.
    Feb 27 2005
    North Wales, PA
    i gotta spread the love.
    Established Member Two Rings tileg's Avatar
    May 01 2008
    Philadelphia
    SICK front plate
    Sep 24 2005
    always in design
    Yup
    The Menzerna, more than most products needs to be done in small sections. It goes on like butter, but removing if it sits can be a bish and result in lots of flake and debris. Next time do a 2'X2' section at most and work your way around the car. I also really do love the Adams products, the Brilliant Spray Glaze makes the car paint pop like nothing else after a polish and wax.
    Oct 27 2007
    In the lab
    Yup
    Will do next time I try it, my supplies are running low so I'm looking to purchase soon. I really liked the workability and correction capabilities of the Menzerna (while leaving negligible micro marring) so I think I'll give that a shot... I've been using Megs Diamond Cut, #83, klasse AIO, Megs #7, Megs #26 almost religiously but I'm looking for more of a one step compound like the Menzernas... Dont get me wrong, the Megs is great but the two steps really kills me, esp since compounding is the shittiest part of the detail imo...
    97 A4 2.0TQM
    Rochester, NY
    i dont think i'll ever understand why JE desgins their 1.8t pistons with so many valve relief cuts...it can't be a good thing when you can have a nice smooth surface like the stock pistons.
    Oct 27 2007
    In the lab
    Quote Originally Posted by pac1085 View Post
    minus the relief for the center intake valve, all aftermarket have that, even my wisecos have that...
    97 A4 2.0TQM
    Rochester, NY
    yeah my wiseco's have the cut for the center intake valve, just like stock pistons.
    i dont understand why JE's have reliefs cut for every valve, and deep ones at that...
    Oct 27 2007
    In the lab
    maybe they expect everyone to go with super huge solid lifter cams lol
    Feb 27 2005
    North Wales, PA
    eehhh who knows. I hope they work. lol
    Oct 27 2007
    In the lab
    they will man
    Feb 27 2005
    North Wales, PA
    pm sent
    Oct 27 2007
    In the lab
    right backatcha sir, ill reply again in the morning as im off to bed now
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    What wheels are those?
    Apr 22 2007
    Riverbank, Ca
    Damn your avant is looking HOT!
    Sell your trani yet? :)
    Feb 27 2005
    North Wales, PA
    the wheels are Ruff Racing 279 18 x 8.5.
    I'm gonna hang onto the tranny for a friend at the moment.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Another detailed Santorin. Jake worked the buffer last week on mine.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    looks good man! now put all those fresh parts to use and get em in your car. So your s4 front is getting fixed or getting replaced?
    Feb 27 2005
    North Wales, PA
    I'll patch it and call it a day. no one cares what your car looks like when its passing you. lol.
    In my mind its a built head or a nice bumper.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    built head all the way man!
    but what did you do with your old motor? not vulturing. just curious
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Feb 15 2007
    marimont
    Damn all this time has passed and still haven't put those s4 sides on? Tisk tisk.
    Feb 27 2005
    North Wales, PA
    i still got to paint one.
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    avant is looking great. keep up the awesome progress.
    82mm je pistons, scat rods, ported & polished aeb head. gt2871r, atp hi flow manifold (ported). 580cc injectors on custom giac tune. Once you boost, you'll never go back....
