    May 02 2008
    2001 audi 2.8 a4
    cincinnati
    race gas question
    my question is can a StocK 2001 a4 2.8 run on a higher level than 93 octane gas and if so what would be the highest or best number to run on without causing any damage? also if you are familiare to the cincinnati are do you know where there is a gas staion that sells high level gas?
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Re: race gas question
    you can run as high as you want as long as it's unleaded.
    TEAM|AXION
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    it would be a waste of your time unless you use some software to advance your ignition timing... dont waste your money on a 2.8
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by 317ssayzarc View Post
    Time to do a little "lemmiwinks" tweaking on a 2.8 for 100+ octane.
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    LOL!!!!
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
