Results 1 to 25 of 25
    Veteran Member Four Rings SurferForever's Avatar
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    power windows . . . turbo timer?
    So i just installed my turbo timer but have no power windows now . . . whats goin on? followed the diy exactly.... somebody please help
    Natasha: 01 A4 2.0 T28/T04 || Silver (Fastest Color)
    034 Motor and Tranny Mounts | Full 3" exhaust with HFC | APR Snub | B&M Short Shifter | APR Boost Gage | RS4 Grill w/ Custom Matched Lowers | 8000k Headlights | 3000K Fogs | M3 Lip Spoiler | Reiger Roof Spoiler | Debadged | Clear Corner Mod | Independent Fogs | Dual Rear Fogs | Zimmerman Cross-Drilled Rotors | Mintex Pads | SS Braided Lines | 18X8 Black ASA AR1's
    Dec 05 2007
    Re: power windows . . . turbo timer?
    Unless you shorted a wire, disconnected one and plugged it up wrong, or shorted a fuse there should be no reason why your power windows are not functioning. Unless it is a faulty window switch or regulator itself. But this is what happened to me. My mechanic unplugged my posotive feed on my battery as he was working with something that made a spark, so he did that for safe measure. But on the way home I noticed that my one touch window up/down was not functioning. Thinking I had to Vag com it, I did not stress it too much. But lo and behold, it started working again. I am not sure if the next day or a whiles later into the day. I think my ECU just had to catch up on some of the programs. Give it a little while and see what happens.
    *we have same ECU and I read that they work sort of like with a brain of it's own.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    After I installed mine. The power windows only work when the car is actually on
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    well.. idk about your problem, but seerlah, anytime you disconnect the battery the one touch windows function thing stops working on all windows. To get it back just put the window up and HOLD the button for a second or two after its all the way up. this resets the one touch function again.
    Dec 05 2007
    Never knew. Thanks!
    Oct 29 2005
    10speed
    San Francisco, CA
    hahaahaa
    Spenser... Ground both wires, not just the one... I drove without windows for quite awhile
    - Clint
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    ground both of what wires clint?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by SurferForever View Post
    both sides of that blue wire you cut from the fuse box
    - Clint
    Senior Member Two Rings Welch1082's Avatar
    Mar 02 2006
    1999 A4 Quattro 1.8T
    S.S.
    i thought that whire need to have an inline fuse and hooked up to the X75?
    Mar 02 2006
    S.S.
    up
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    Quote Originally Posted by Welch1082 View Post
    it does
    Mar 02 2006
    S.S.
    what wire do you ground then?
    Mar 02 2006
    S.S.
    what blue wires is he talking about grounding?
    Mar 02 2006
    S.S.
    someone please help, my windows will roll up and down with the key in the lock but not with the switches?
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    ditto
    Mar 02 2006
    S.S.
    what tt do yo have?
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    greddy - the one that fits right in the cup holder spot
    Mar 02 2006
    S.S.
    ok i have th hks so at least i know it wasnt soemthing with the tt itself.
    Mar 02 2006
    S.S.
    took it all back apart to day and i had the wrong blue wire hooked to the X75. I had the one on the fuse box hooked up. check the #6 fuse wire you may have them backwards.
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    this fixed your problem with the windows?
    Mar 02 2006
    S.S.
    yup
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    wait, so which blue wire did you hook up to the x75 post? the directions say to hook up the fuse that you cut...
    Mar 02 2006
    S.S.
    when you cut the wire going to the fuse pannel you will attach the inline fuse holder to the wire that is going to the harness not the wire that goes back in to the fuse pannel
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    well ok, i did that part.
    Mar 02 2006
    S.S.
    i swore i did to i would just double check cause that fixed it right away for me
