- Time for me to upgrade... Already. I am moving up to either a full GTRS or a 2871R, so this stuff has to go. The kit has about 18k on it. No leaks and the kit runs very strong. It peaks at 24lbs and holds 19lbs through redline. The turbo achieves full boost at 3800 to 3900 RPM. I chose tu use REVO BT Software as opposed to GIAC. You will need to acquire your own software.
- The kit is still currently on my car. It will be removed upon sale.
The kit includes the following:
Garrett 28R Turbo (1)
Wiring Adapters for Injectors (4)
Fuel Injecors (4)
Oil Feed and Return lines (2)
Turbo Inlet Hose (1)
Adapter Plate for Turbo (1)
Turbo Support Bracket (1)
3" VR6 MAF (1)
Test Pipe (1)
Disclaimer - I will supply the used gaskets that I from the kit, But I would advise getting new ones to install
This kit retails for $3700.00 w/software.
I am selling for $1700.00 w/o software.
