Results 1 to 9 of 9
    Registered Member Three Rings
    Aug 06 2007
    02 Audi A4 1.8T Q Tip
    New Jersey, USA
    245mm or 255mm rear rotors ???
    How can I determine the size of my rear rotors (without taking them off) ???
    I have an '02 1.8T Quattro Tiptronic with Sport Package.
    Dec 25 2004
    Earth
    Re: 245mm or 255mm rear rotors ???
    245mm is OEM for the 1.8T
    255mm is OEM for the 3.0L
    Aug 06 2007
    New Jersey, USA
    Quote Originally Posted by MikTip View Post
    Thanks MikTip
    Sep 07 2007
    San Francisco, CA
    Like MikTip said, you most likely have the 245 mm rotors. If you want to be 100% sure, call the dealer w/ your VIN and they will be able to tell you.
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    If you're unsure, here's a post I made on another Audi forum about how to measure without yanking the wheels.
    Not wanting to pull the wheel off again, I measured the circumference of the center hub using a piece of magnet wire (465mm), then measured the edge of rotor to center hub(50mm). So, take the circumference, divide by pi, multiply the edge to center by 2, and add them all up. :)
    (465/3.14)+(50*2) = 248mm
    Which is close enough to 245mm for me, a 3mm difference is easy to account for given the measuring methods.
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    my 02 1.8T had 255mm. thats why i let the mechanic order the parts. had to resend the junk back because it was not the 245 as expected. gotta love audi. they just take anything out of their parts bin when they are switching years and its pot luck.
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Aug 06 2007
    New Jersey, USA
    Wwwhhhhhhhyyyyyyy.... A4TL, WHY !!!!!!
    I was happy with MikTip's response.... now you have me thinking HARD if I ordered the correct rear rotors.
    Nov 06 2006
    335is
    atlanta
    take the wheel off and hold them up?
    Aug 06 2007
    New Jersey, USA
    i went to dealer with VIN
    i have 245mm
    thanks guys
