Results 1 to 12 of 12
    Apr 18 2007
    ny
    Question Rattle sound at 4k rpm, what could it be???
    Wuts up guys, I have noticed that when I push hard off the line I get a rattle sound between 4-5k rpm's. Could this be a bad DV, what does a bad factory DV sound like? It's wierd because it only happens when I push off the line and hit 4-5k, anybody have any ideas? Thanx
    Feb 17 2004
    Sterling, VA
    Re: Rattle sound at 4k rpm, what could it be???
    It might be a heat shield. Can you duplicate the noise while sitting still and revving?
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Apr 18 2007
    ny
    Heat shield sounds like a good suggestion, I will rev in neutral and try to duplicate sound.
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    Yeah , mine made noise like that alot!, and it ended up being the heat shield near the turbos.
    2004 Audi A6 2.7T
    Apr 18 2007
    ny
    My car is actually at the dealer today to replace my headlight ballast, so I called up my SA and told him to look at the heatshields because Im getting a lot of rattling. Lets see what happens.
    Apr 18 2007
    ny
    Dealer told me that it actually is the turbo heat shield and CPO does not cover any adjustments, but would cost me about $175.00, I tld him I would do it myself lol Is this an easy task?
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    CPOsucks
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Mar 30 2008
    Pittsburgh
    Quote Originally Posted by A62TURBO View Post
    no, it wasn't easy at all, my indy shop did it in like an hour, and thats with all the tools and a lift.
    2004 Audi A6 2.7T
    Senior Member Two Rings a62.7t4ceo's Avatar
    Mar 16 2007
    I worked on the heat shield on the driver's side when I replaced my EGT sensor. It was very easy. Remove coolant reservoir, unclip large vacuum tube and voila. I was missing a bolt which explained my rattling sound. The bolt is $1.38 and it takes two. The part number is 10005306. Make sure you wear gloves when moving the heat shield. The edges are sharp. It'll take 15 - 20 minutes.
    Apr 18 2007
    ny
    Quote Originally Posted by a62.7t4ceo View Post
    Thanx for that info
    Hey Frank, maybe you need a new Indy shop lol
    Mar 30 2008
    Pittsburgh
    man that shop is a life saver! its just it was in a hard to get to place! and my shield was cracked, and missing a bolt, and cracked by the other bolt, it was pretty bad.
    2004 Audi A6 2.7T
    Mar 16 2007
