Results 1 to 6 of 6
    Active Member Two Rings syonarag60style's Avatar
    Jul 05 2004
    2000 S4
    Bangor, PA
    No boost, no power, won't rev properly, cannot connect with Vagcom??
    My 99 A4 has just decided to start giving me some issues.....I don't know the history of the car, I bought it like this.
    First, it won't rev out in neutral. For example, hit the gas, rev it up, get off the throttle, then back on, and it'll drop all the way to around 900 RPM's, then it'll start climbing again, even when you had your foot to the floor the whole time.
    Second, when I do get it to drive (above 3000 RPM's, it has no power whatsoever, basically, no boost. You can't hear the turbo spool, whether driving or revving in neutral.
    And third, I cannot connect to it with vagcom. The cable works, my vagcom works (confirmed by using it on my S4 and my wifey's A4), but I cannot get it to communicate with this car. I plug it in and the cable blinks red sometimes, sometimes green, sometimes orange, but won't read. It started to read the car once, then lost connection. I got Vag to connect and got two codes, before it lost connection.....VAG-COM Version: Release 512.4-UD
    Sunday,01,June,2008,15:42:45
    Chassis Type: 8D - Audi A4 B5
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Address 01: Engine
    Part No: 8D0 907 557 P
    Component: 1.8L R4/5VT MOTR HS D06
    Coding: 06201
    Shop #: WSC 06335
    2 Faults Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    17953 - Throttle Valve Controller: Malfunction
    P1545 - 35-00 - -
    Readiness: 0110 0101
    That was as far as it got, then it lost it and won't reconnect....I'm kinda at a loss here....the battery did die, and then the car was jumped, hence the power supply terminal (I think)...the shop its at left the interior lights on, but maybe no??
    Anyone with some suggestions where to go? Possibly an ecu failure hence the connection issues? N75? Mass air? Kinda at a loss right now where to go with this
    Oh, also checked fuses.....only one that was popped was cig lighter, replaced that, did nothing
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: No boost, no power, won't rev properly, cannot connect with Vagcom??
    Sounds like the throttle body needs to be adapted.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Jul 05 2004
    2000 S4
    Bangor, PA
    Quote Originally Posted by t1demont1 View Post
    Guess I should have said I tried that already....
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    have u checked the fuse behind the radio? pull ur radio and if that fuse is busted replace it. mine blew when i jumped my car couldnt vag my car, replaced it and i was able to vag it
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Apr 22 2007
    2010 Audi A3 2.0T Quattro Prem+
    Boston, Mass
    Maybe try pulling the abs fuse out from the panel on the side. I have an aftermarket radio and it only works that way for me.
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Have you disconnected the battery for at least 10 minutes? A noisy jump start or power loss can make the ECU and other computers do strange things.
