Results 1 to 40 of 73
Thread: Check Valves!
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Check Valves!
    What do yours look like?
    Ordered all(?) 5 from Audi with clamps. Just waiting for my Oetiker tool to get here and I'll change them all out.
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    Re: Check Valves!
    mine look like the replacement ones you have in the bag. I have a 02 1.8t
    Established Member Two Rings Zoidbort's Avatar
    May 20 2008
    Victoria, BC
    Re: Check Valves!
    Those things are so ridiculously over priced. I wish there were better 3rd party made ones!
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    Re: Check Valves!
    yah its called usp plastic kynar check valves got them on mine $1.66 or so a piece.
    work great :)
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Re: Check Valves!
    mine look like yours and www.ecstuning.com sells them
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    Re: Check Valves!
    I just replaced one of mine that was cracked the other day. Way over priced....
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    Re: Check Valves!
    you can eliminate a lot of those vacume lines. i will post up pics of mine. you will need to get rid of your secondary air. but it is not needed for anything. and you can clear the code for it with vag com i think.
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    May 20 2008
    Victoria, BC
    Re: Check Valves!
    Sweet, post some pics eh!
    Jun 30 2007
    Raleigh, NC
    Re: Check Valves!
    yeah, if anyone needs some - I'll be removing my evap, sai, and pcv tomorrow - so i'll let mine go for like 10 bucks (for the whole lot) lol
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Re: Check Valves!
    Quote Originally Posted by Zoidbort View Post
    The four standard ones were about $6 a piece and the multifunction was $20. Doesn't seem overpriced to me.......
    Nov 06 2006
    335is
    atlanta
    Re: Check Valves!
    there's a few different sizes this one is actually too small. but i did put it on the bmw to prevent the exhaust from closing below 2000 rpm so it wasn't a loss. there's a thread around here we had a while ago discussing these.
    btw you best replace the one before the N80 purge valve before it lodges plastic in the N80 purge. thats exactly what happened to me and it cost me $96 for a new N80 purge valve.
    So replace them with stock or otherwise, but just replace them :)
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Re: Check Valves!
    Happen to have a pic of where the N80 is? Not sure if I ordered a replacement for there.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Check Valves!
    The N80 is in the first picture you posted. look at the valve just to the left of the bad check valve.
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Re: Check Valves!
    Ha, alrighty, then I'm good to go. Thanks.
    Senior Member Two Rings GermanAudi's Avatar
    Jun 01 2008
    2003 Audi A4 1.8T Multitronic
    San Diego, CA
    Re: Check Valves!
    Sorry to sound like a noob, but what is a check valve and what does it do?
    Nov 06 2006
    335is
    atlanta
    Re: Check Valves!
    allows air to pass in one direction only. blow on one and and blow on the other you'll figure it out.
    trust me that check valve before the n80 is going to cost you $96 if you don't take PM measures.
    btw that "special check valve" that has 3 nipples, look at it; all it is a TEE before a check valve. $1.66 for check valve. $.20 cents for tee. Same goal.
    if you think my ideas are crazy go the passat world or b5 forums they've been rocking the USP kynar check valves for a long time.
    Zero problems. no codes. works great.
    I don't dislike oem but man they are expensive for what they do. even at $6 thats still a $1 check valve :)
    Jun 01 2008
    San Diego, CA
    Re: Check Valves!
    The dealership told me that my one-way check valve is bad. The quote they gave me was $104 to fix!!
    2003 1.8T Multitronic CVT, Canvas Beige Metallic
    GIAC Stage 1 || 710N TT Diverter Valve || 6000K Xenon HIDs || VMR Vent Boost Gauge || Eibach Pro/Bilstein Sport Suspension
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Re: Check Valves!
    Quote Originally Posted by GermanAudi View Post
    You have to figure labor is in there. I'd just buy the part and do it myself, hell, I am doing that.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Check Valves!
    Quote Originally Posted by 102487thedude View Post
    You can only temporarily clear the SAI code for 'insufficient flow' with VAG-COM. It will, eventually, come back.
    Since Mark@ASP is tuning your car, ask him to permanently remove the code. He did that on my car for me. I have no SAI system and in the past 5,000miles I've had his software I've never gotten a CEL for SAI.
    -Doug
    Veteran Member Three Rings A4Avant02's Avatar
    Feb 05 2008
    '02 A4 Avant, '74 Triumph TR 6
    Folsom, Cal
    Re: Check Valves!
    I had a vac leak and when I went to fix it the valve seemed to crumble. I ordered the lot and replaced them as well as some section of vac line. Plastic parts and heat just don't mix well.
    Jun 01 2008
    San Diego, CA
    Re: Check Valves!
    What are some symptoms of a worn check valve?
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Re: Check Valves!
    Do yourself a favor and don't use those one-time clamps and get some screw clamps. Much easier to work with if something goes wrong.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Registered Member Three Rings
    Jun 21 2007
    Fort Lauderdale,FL
    Re: Check Valves!
    I'd like to know this too!
    Registered Member Three Rings SlappyB6's Avatar
    May 14 2008
    W-S, NC
    Re: Check Valves!
    Quote Originally Posted by A4TL View Post
    work great :)
    Where did you get yours, and what size would I need to replace the one in the first picture of this thread?
    02 A4 - 5spd - Sport - VM DP
    Capt. Obvious - "Not me. I fart rainbows, shit rose pedals and piss excellence."
    Dec 06 2007
    Re: Check Valves!
    what tool is that to remove the clamps?? and A4TL what check valves are u using???
    -Kirk
    BetaAlphaTau Member #58
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Re: Check Valves!
    I like ma Oetiker clamps. I don't foresee there to be any problems. They pop off with a flat head screw driver, or cut them with some dikes. And I have the clamp tool. Really no reason to replace them with a lesser clamp.
    Aug 06 2007
    02 Audi A4 1.8T Q Tip
    New Jersey, USA
    Re: Check Valves!
    Quote Originally Posted by 400HPA4 View Post
    What is the function of the N80?
    Nov 06 2006
    335is
    atlanta
    Re: Check Valves!
    usp plastic. i bought a variety. man there was a big long thread on this already. on this forum, and on the passat forum. this isn't something new. old school stuff.
    There is a big ass vacuum pump near the gas tank. It sucks fumes back into the tank. The n80 opens and closes to vacuum out these gases. When it fails (open 100%) it would suck most of the engine vacuum away causing massive misfires on all cylinders and damn near stalling.
    When it fails partially open it causes the leak code, mushy brakes, hard starts, especially after filling up with gas on a hot day.
    Probably could find a $20 ford part that does the same thing lol. it just is a PWM air valve. The N75 roughly does the same thing :) probably why N75 is numbered close to N80 :) man i didn't realize that until right now
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Re: Check Valves!
    I know you didn't just hint at using a Ford part on an Audi................
    Jun 21 2007
    Fort Lauderdale,FL
    Re: Check Valves!
    Ok, so we know the symptoms of a bad N80 now, but what are the symptoms of a bad check valve?
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Re: Check Valves!
    Quote Originally Posted by kepone View Post
    You touch it and it disintegrates in your hand.................
    Jun 21 2007
    Fort Lauderdale,FL
    Re: Check Valves!
    lol, well i meant more like, how does the car run if one has already disintegrated in your hand
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    Re: Check Valves!
    The signs of bad PCV system are not always obvious but one part of the puzzle is a blown valve cover gasket. If you can't get good ventilation off the valve cover, pressure builds up and it starts seeping oil. Also those check valves can fail internally by allowing back pressure when they shouldn't, which is something you can't see visually - requires removing thing and trying to blow through it the wrong way.
    Generally a good idea to just swap them out as part of long-term maintenance. On my last car I did them at about 160,000 miles, and found that some of them needed it and others were still fine.
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
    Jun 01 2008
    San Diego, CA
    Re: Check Valves!
    so you cannot feel the car run differently (i.e. hesitating, sputtering, rough idle) if you have a worn check valve?
    How many check valves would you have to replace if you were to do routine maintenance?
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: Check Valves!
    they are bad when they look like the pictures at the beginning of this thread. if you try to blow through the black end of a good one, no air will flow through.
    {99.5 Avant}
    Nov 06 2006
    335is
    atlanta
    Re: Check Valves!
    dude if the thermoset plastic looks in any way compromised or you can't blow in the obvious direction, bad.
    i'd say mine were hosed at 74K miles. turbo heat kills.
    if you haven't done them, guess what. you better. time+heat=kills.
    I will assume you've done the braided vac lines too.
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Re: Check Valves!
    Five
    Mar 13 2006
    2002 A4 1.8TQM
    Columbus OH
    Re: Check Valves!
    Maybe I'm the odd man out... but it seems like there are two types of people posting here. The ones that know how easy this is, and the one's who don't have a clue. Saddly, I'm one of the ones that doesn't have a clue. I've got 107k miles on the clock now, and have yet to replace one of these things!
    Can we get an official writeup on this subject, instead of piecing parts together throughout this and the adjoining threads?
    How many total? (ok, 5)
    Where are they located? (pictures with arrows would be awesome!)
    Are they all standard sized, so we can pick them up at a local auto parts store? They all the same size (and then the one needs a T also?!).
    Anything else we need to know/buy if we want to go replace all of them this weekend?
    On a related side note... I noticed the braided vacuum lines don't have hose clamps on them. Are they plumbed in a way to not see boost? What keeps them from popping off?
    Upgraded the motor a little, brakes a little more, and suspension a lot.
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Re: Check Valves!
    There are five, four are identical, one is slightly different. The different one has a small, long nipple coming off of the left side that basically turns that check valve into an offset t-shape. That one is located above the intake manifold. Of the remaining four, three are located on the right side of the intake manifold. Those are all basically in the same area. The fourth, which is next to the N80 valve, is on the left side of the engine bay, about halfway up.
    You can't just pick up check valve anywhere, they are some what of a specialized part. Possibly dealer only in the automotive world. I don't know if there is a Napa type of aftermarket for that. I suppose someone could look into that. As has already been said, there is a company called USP that makes them for some other function. It is the same type of part though, so it will work. And is arguably better than OEM as it's plastic instead of hardened rubber. I won't argue that either way, choose whichever you'd like. Since they are generic though, you cannot get the T'd one from them. You either need to go to the dealer for that one (or Napa if those exist in that world), or you have to plumb a T in. Why you would want to add to the headache by plumbing in more connections is beyond me. But that is an option.
    They are held on by the stock Oetiker clamps. You can use a flat blade screw driver to pry them off. Of just use a sharp pair of dikes and cut them off. I prefer this method as it's quicker. You can replace them with new Oetiker clamps which you can source at the dealer or various other places. But then you will need to also purchase the special clamping tool for them. This is what I did as I am a fan of OEM, and the Oetiker clamps work very well. Or you can replace them with standard screw/band clamps that you can find pretty much anywhere. I think they look cheap though and don't want my engine bay littered with them. That is just a preference though, and most people are not that anal. You need two clamps per valve, three clamps for the T'd valve.
    Install is as easy as cutting the old clamps off. Popping the hose off either end of the valve. And then reverse process. The air flow is directional though, so make sure you install the new one the same way you took off the old one. If you can't physically tell (I think the USP ones are pretty symmetric); when you take it off, blow through one end and remember which hose that was attached too. When you put the new one on, blow the sides until you hit the side that duplicates what the old one did, and install it the same way. Just do one valve at a time to reduce the risk of putting one on backwards.
    Clear as mud? Good..................
    Established Member Two Rings Teratorn's Avatar
    May 30 2008
    Ashburn, VA
    Re: Check Valves!
    Excellent write up! I just replaced one of mine and it was the one next to the N80 valve. It looked like one of the pictures posted where it's turning white. The symptoms I had for that particular valve leaking air is rough idling and hesitation on first gear when taking off from a complete stop.
    Can this be detected by a boost leak test, or would there be a drop if you had a gauge?
